Capacitor Response Time? Blue Meter?
  • bigbeark
    • Jan 2010
    • 661
    I have recapped several boards that were unresponsive and ran hotter than I thought they should. All the old caps were high-quality Rubycon MBZ and Sanyo WG.
    When I tested them in circuit with the ESR meter, their values were all low.
    When I remove them from the board and test ESR and Capacitance, all are within spec.
    But when I recap with the same high quaility NEW caps, the boards run cool and without annoying lagging.
    My theory is that as caps age, they become less responsive, IE they take longer to reach the deisred ESR and capacitance. I have seen this for sure on caps that fail ESR tests, the ESR SLOWLY falls point by point, wheareas the new caps seem to fall almost instantaneously to the low reading.
    Do those of you who use the Blue meter observe this phenomenon of fast versus slow response in your meter readings?
    I invariably end up recapping the entire board, good cap and bad cap brands all get tossed.
    It would seem to me that the boards with the good caps never really die, they just sort of fade away..
    Whereas the Jackcons, JPCons etc fail early in the VRM section. I brought an ECS board back to life by replacing only the VRM caps and the board is REALLY quick, I suspect because there were very few hours on the board when the VRM caps failed.
    Your comments welcomed.
  • severach
    • Aug 2007
    • 1055
    Re: Capacitor Response Time? Blue Meter?
    I had a 3.3v buck circuit supplying about 2 amps through a FDS6982S SOIC-8 dual N channel MOSFET. With the original dented Panasonic FJ 1500uf 6.3v ESR=0.05 the FDS6982S would burn itself out within a minute. The buck inductor would also run hot. With a new Nichicon HM 1500uf 6.3v ESR=0.01 the circuit runs forever cool as cucumber.
    Perhaps the dent damaged something that doesn't show on a capacitor/ESR meter. Perhaps cutting ESR by 5 greatly increased the current capacity of the circuit.
    sig files are for morons
      by momaka
      03-15-2023, 10:17 PM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • rybby
      Acer Aspire 5 A515-51 power on but black screen
      by rybby
      I have an acer aspire 5 a515-51 that turns on but has a black screen.
      This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
      Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
      06-16-2023, 09:41 AM
      Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
      This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
      09-07-2024, 05:50 AM
      Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
      This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
      09-07-2024, 05:00 AM
