Re: Do you got Evercon datasheets ?
RS-Components have some too and so should Farnell
@PCBONEZ
Thanks for your pm - I will have a look at the Panasonic FM.
Are they easy to get on Ebay ? I see they are not sold here on badcaps netshop.Leave a comment:
The datasheets I got were from a WebArchive copy of http://www.gsc-cap.com/ from 2004 - does that seem old enough?Leave a comment:
They made the LE and RE series from sometime in the 90's until they went *poof* [or at least their site did] in 2005.
Both of them sometimes had the series marked and sometimes not. Had to go by the colors.
Then in '07 Evercon showed up at http://home.so-net.net.tw/gsccap/NEW/e-p1.htm.
It showed both Sacon and Evercon info for a while.
Then that site went *poof* in 2008 - just about the time the crap FZ series were getting famous.
.Last edited by PCBONEZ; 12-07-2010, 06:13 PM.Leave a comment:
Just a trivia
GSC full name = GEN SALES ELECTRONIC CO., LTD
http://web.archive.org/web/200302050...sc-cap.com.tw/
.Leave a comment:
That cap probably dates back to when GSC only had two series and they went by the sleeve color.
RE was Green.
LE was Black.
I think you have an LE there.Leave a comment:
That isn't an NK series.
E5NK is the date code.
RE was Green.
LE was Black.
.Leave a comment:
I'm not seeing anything that makes sense as a cross reference.
They make caps to order so presumably who ever orders can have them marked with their own series code.
.Leave a comment:
Maybe.
I'll find the link. It isn't straight forward.Leave a comment:
I haven't seen a situation on a mobo that needed that but that doesn't mean none exist.
If you can draw out the schematic for that section you should be able to figure out if the polarity can change direction.
If it can't then you don't need a non-polar cap.
.Leave a comment:
You think Capsun might have the spec sheets?Leave a comment:
GSC=Evercon=Sacon
Not a manufacturer, just a distributor.
They had their caps made elsewhere and had their name put on them.
Capsun was their OEM supplier. [The actual manufacturer.]
Capsun supplies some other CH & TW brands as the OEM. [I think including some OST.]
SamYoung is Korean and not related to them other than distribution.
Samwha is also not related to them other than distribution.
Joint ventures are usually just distribution networks.
They don't make each others caps but they sell each others caps.
.Last edited by PCBONEZ; 12-07-2010, 03:33 PM.Leave a comment:
You're right. The dimensions are wrong. The Capxon NK is 10x16 and the Jamicon is 12.5x25. Mine is 8x11.5.
But still I can't help but wonder, the 330uF 6.3 Capxon NK is 8x11.5. If I had the datasheet for this motherboard, would it indicate whether a bipolar cap should be placed there?Leave a comment:
Not likely. All i've seen have a large NP printed on them, and are significantly larger than a polarized cap of the same value (that's normal since they are two caps in one).Leave a comment:
How can I check if my GSC cap is non-polar? I'm asking because I find two interesting references to an "NK" series capacitor one from Capxon and one from Jamicon, both of which are non polarized.
Is it possible to have a non-polar capacitor on a motherboard? Maybe for the sound subsystem? Though it is right next to the PCIe x16 port.Leave a comment:
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
Channel: General Capacitor Questions & Issues
by CdDvdFlashI've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
(Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...-
by Tomek188Hello,
I need datasheets for EN7521 and MT7520 (similiar chips). This is GPON ONT.-
Channel: Common Parts Library - Datasheets
01-17-2025, 01:47 PM -
by petehall347i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
by ten-dHi all!
I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...3 Photos-
- Loading...
