Trouble identifying some Samwha caps
  • jondilly1974
    • Nov 2009
    • 38
    I have some Samwha caps out of a Sanyo plasma HDTV that I need to replace. Having trouble finding spec sheets, or any reference at all, for the PT series Samwha caps. Here are the markings:
    Samwha PT
    50V
    100uF
    105C (M)
    U3A
    Thanks in advance!
  • cfandt
    • Dec 2008
    Re: Trouble identifying some Samwha caps
    If you haven't yet, try hunting around on: http://www.samwha.com/electric/templ...product23.html .
    I could not see any reference to the PT series you report - either in existing products or in discontinued.
    By now you probably have found replacement(s) for the SAMWHA parts you speak of.
    Regards,
    -Chris F.
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
      by momaka
      03-12-2025, 03:42 PM
    • crosswinds
      Assistance with identifying replacement caps on ASUS P5VDZ-MX
      by crosswinds
      So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
      Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
      Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
      Its a ASUS P5VDZ-MX board.
      I would really appreciate some assistance on what the best replacement caps would be for these:
      Panasonic(M)...
      04-17-2024, 04:25 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • fl0w
      GeForce 6800GT recap, need help identifying caps and finding replacements
      by fl0w
      I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
      But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
      I need to replace:
      • 2x 2.5V 1500µF => I plan to use this
      • 2x 16V 330µF=> I plan to use this
      • 1x 6.3V 680µF=> I plan to use this
      Am I correct with the cap choices?
      Thanks for...
      10-02-2024, 11:28 AM
