125 Degrees Capacitor's
  • rarack22
    rarack22
    • Oct 2010
    Hi all, new here. Still learning. Used to working on Wii's Xbox's etc... and repairing traces but just starting on capacitor's.
    I think I have figured everything out except my capacitor's on my board are listed as 125 Degrees CH. I can not find any capacitor's rated at 125 Degrees, 105, but not 125. Should it be safe to replace most of the board with 105's? That is all I am trying to figure out.
    I have a Gateway HD2400 monitor. The monitor works great except the touch sensitive menu does not work most of the time and is unreliable. I have tested the thin ribbon and it checks out fine. I am assuming it is the capacitor's on the video card located by the ribbon connector. Especially now that I found out the capacitor's are Su'scon. A few are SAMXON but I figure why not replace them all while I am at it.
    47UF 16V
    10UF 25V
    100UF 10V
    22UF 16V
    These are the ones nearest the ribbon connector. I am going to chart the rest of the capacitor's tomorrow. If anyone could shed some light on the 125 Degrees CH I would be more then appreciated. I have searched for a few days now, here and other places on the net. Hands down this is the best site I have found and look forward to getting to know it. Thanks all who may post there thoughts.
  • japlytic
    • Oct 2005
    • 2086
    Re: 125 Degrees Capacitor's
    Welcome, rarack22!
    Replacement of 125C units with 105C units depends on the circumstances, which includes being near hot areas and/or areas with poor ventilation.
    Here is a list of manufacturers and series of 125C (or higher) electrolytics:
    Nippon Chemi-Con: GXE (2000-5000 hours), GPA (3000-5000 hours), GXL (5000 hours), GXH (1500-2000 hours - 135C)
    Nichicon: BT (2000-10000 hours), BW (2000-3000 hours - 135C), BX (150C)
    Rubycon: ZT (1000-4000 hours), RX50 (1000 hours - 150C), RX30 (1000-4000 hours - 130C), HBX (4000 hours), HRX (3000 hours)
    Depending on board space, you can upgrade to higher voltage units if lower voltage units are not available in a lower capacitance (e.g. 47uF 16V are not available, but 47uF 50V units are available).
    • M98Ranger
      Sorry for the resurrection, but I felt like I had something important to add.
      It's nothing new, but if the design was for a higher temperature (125C for instance), it was for a reason. As an engineer myself, another engineer wouldn't specify a temperature rating of 125C just to make the design more robust. It's all about cost and matching component life of all the components together so that the 'weakest link' breaks at about the same time as all the other components.
      That said, if you increase the rated voltage, most people understand that there is an increase in ESR, which is correlated to an increase in temperature due to inefficiencies, etc.
      So the IMPLICATION that I am trying to point out is that;
      1. If 125Celsius is a design temperature (and it most likely is ...especially taking into account the enclosure of the Xbox)
      and
      2. If you reduce that sustainable temperature to 105Celsius
      and
      3. If you try to correct for the reduction in temperature by increasing the voltage rating...
      4. Then you are going to overheat the capacitors and LIKELY blow them turkeys out long before their "TIME" was INTENDED to come.
      2 Cents worth from a Mech Eng.
      • larrymoencurly
        • Oct 2004
        • 960
        Why did my parents' ancient RCA top loader VCR (by Panasonic) contain so many 125C capacitors?
        • cashkennedy
          • Aug 2011
          • 668
          Because VCR was first used for porn, and things could become hot / and or steamy fast.
          In regards to the actual issue, most low esr caps are rated for longer life / and higher temps then regular general purpose caps. The device that has the 125C caps probably chose the cheapest low esr cap that matched some other specs they wanted. Cap life expectancys are time at max temp, almost no devices ever built are running at 105 or 125C very close to the capacitors. (Except maybe ATI x19xx video cards . But by going with a 125 C cap and running it at half that temp, you can get maybe four times the longevity out of the capacitor... so instead of 2000 hours (under 1 year of use) you get 8000 hours... If caps only lasted their life rating wed have some serious work to do, cause ive almost never seen any rated for over 10,000 hours, and have seen many devices plugged in for 20 years / and or running for that long...
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          • zesko
            xps 9520 ribbon cable
            by zesko
            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
            There is 2 models, idk which one is needed on my laptop.
            0xkvng
            00vpr2
            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
            thanks...
            10-23-2025, 05:03 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • Takeatry
            Yet another Samsung QLED Boot Loop
            by Takeatry
            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
            10-04-2024, 02:57 PM
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
