What's the best capacitor manufacturer?
  • Funkmeiser
    • Sep 2023
    • 10
    • United States of America
    I need answers!
  • petehall347
    • Jan 2015
    • 4440
    Re: What's the best capacitor manufacturer?
    Originally posted by Funkmeiser
    I need answers!
    any particular series of capacitor ?
    • Funkmeiser
      • Sep 2023
      • 10
      Aluminum Electrolytic Capacitor with screw-in terminals (With a high microfarad value and voltage)
        • 31214
        maybe kemet
        • Funkmeiser
          • Sep 2023
          • 10
          Radial Electrolytic Capacitor with screw terminals And a large amount of microfarads and volts
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
