i think i need more caps!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    sorting part of my inventory.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I'll take some 2200uF 10v 10mm radial alum-electrolytic low-ESR's..... as many as ya can spare
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      none of those on hand.
      i can see if i can get you some from a surplus dealer here in town.
      he has several cases of low esr nichicons i will be getting.
      i service stuff for him so i get to go through new arrivals and work it out in trade.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        cool!! Nichicon is in my top 3 of preferred replacement caps! lemme know what ya come up with and what ya gotta have for 'em!
        Team : 49813
        Join in!!
        Team Stats
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
