NEC with KY caps
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    NEC with KY caps
    Hi have an NEC 19" monitor with KY caps (NL series )
    I believe these are made by chemi con
    They dont seem to be bloated or not working but was told that it did not work well it seem fine think operator error
    Was just wondering as i have it apart is it worth changing these for rubycon caps
    T I A
  • retiredcaps
    • Apr 2010
    • 9271
    Re: NEC with KY caps
    T I A
    What NEC model?
    What is wrong with the LCD to make you think the existing caps are bad?
    Something wrong with "." key?
    --- begin sig file ---
    --- end sig file ---
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I don't think so unless I missed what you mean.
      KY is a Chemi-con series. [And therefor aren't NL series too.]
      Chemi-con caps have a shield logo.
      Mann-Made Global Warming.
      - Dr Seuss
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Sorry long day so far
        Its a NEC Accusync LCD 92VM Model L194F2
        Well i was told it wouldnt turn on so doing as i always do ignored what i was told and plugged it in screen came up no video signal as expected as no computer connected .
        So then connected laptop and it fired up showing bootup screens then promptly diplayed perfect picture
        This is where i started to scratch my head not because of a problem but i cant find a problem so opened up monitor checked all caps no bulgers
        No bad voltages everything measures out ok
        Couple of the caps look a bit darker than the others so just thought while i got it open maybe should just change the caps.
        Just think that maybe the guy hadnt checked his power lead for a blown fuse
        and just assumed the monitor had given up on him
        • retiredcaps
          • Apr 2010
          • 9271
          Do the caps have a date code? Something like T0723 to indicate 2007 week 23?
          If the caps are fairly new and the monitor is working, I would personally not change anything. I have been United Chemicon caps for the last few months and so far everything is good.
          Others, however, might go ahead and recap.
          • sabre504
            • May 2010
            • 449
            • United Kingdom
            PCBONEZ is right i mixed up front of the caps read shield mark ) KY 16V 1000uf.
            The back reads : (M)105' 4(7) NL
            I was reading 2 side by side (said it had been a long day) .
            • retiredcaps
              • Apr 2010
              • 9271
              I believe
              (M) means +/- 20% tolerance
              105 is 105C
              4(7) might be 2004 month or week 7?
              I'm sure PCBONEZ knows for sure.
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                Temp bit i ok with.
                But if you are right about dates then maybe it is time to change them, though must admit they look good (i know that means nothing)
                Had bought this to use the screen for an Acer i am repairing but as its working seems a shame to break it up ,this is the second unit i have bought this month for spares that appears to have nothing actually wrong with it.
                Dont get me wrong i not complaining but now got to source another screen to finish the Acer
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  4(7)
                  4 - is 2004 - I'm sure about that part.
                  (7) - I think is month 7 but not 100% sure.
                  I know the year is right because it consistently matches the year in date codes on other brands of caps on the same boards.
                  No idea what the NL is.
                  Characters in those two positions are different all the time.
                  - Dr Seuss
                  • sabre504
                    • May 2010
                    • 449
                    • United Kingdom
                    Ok thanks for the input .
                    I will run it on test for a few days and see if i can get it to stop working other than that as i said would seem a shame to rob it of parts when its working fine
                    Thanks again
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Behemot
                      Chemi-con ends production of large part of caps
                      by Behemot
                      Been recently informed that NCC is EoL'ing many caps from ALL series, some series (like LE, long life, medium ESR/RC) will end as a whole.
                      From what I've seen, D5, D6.3 and D8 caps are affected. So ALL the small caps, either standard or low-ESR, and many caps in filtering (in D8, especially FSP, but many others use that in output filters in SMPS).
                      Last order accepted in 2024, so I will try to restock and pre-stock as many as possible to keep them caps flowing, but at the very last about 2030 I will most likely run out. Could only hope that other manufacturers won't...
                      07-02-2022, 04:50 PM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
