Do contemporary motherboards generally have components on both sides?
  • Lapsmith
    • Jul 2025
    • 12
    • USa
    I am repairing a Dell-5520. I haven't removed the MOBO yet, but was wondering if they are typically double sided with surface munt components on each side? I found the GR Board View File, and using FlexBV5, haven't figured out how to display the bottom side (assuming there is one).
    • 20952
    press the spacebar to flip the board
    • Lapsmith
      • Jul 2025
      • 12
      • USa
      Got it, thanks! I also just learned if you search for a component, clicking on it will tell you if it is on the top or bottom, at least on the Dell 5520 schematic.
      One follow up question. Is there any way to superimpose the bottom view on the top view, maybe with a different color) so you can see how components line up?
      • obelix24
        A1534 820-00045 - USB-C not working both sides
        by obelix24
        Hi All,
        I just got one Macbook 12" that was not powering on. I found out that the battery was flat on right side so I charged it little bit with power supply and the MacBook turns on.
        Problems that I have when I connect everything I can see for second apple logo and it it dims down, then there is apple logo with progress bar also only for second and then dims down. I found that issue is with trackpad (probably keyboard part) as when I disconnect keyboard from trackpad MacBook boots up normally. I took off the black cover on keyboard I was expecting some water damage...
        11-07-2023, 07:44 AM
      • qwerty99
        Xbox 1.6 Motherboards and Polymer Capacitors
        by qwerty99
        Hello!
        I need to change the capacitors on my three original Xboxes.
        Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
        The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
        The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
        I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
        06-26-2022, 12:53 AM
      • Foetuss
        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
        by Foetuss
        Hi all
        Hope this is in the correct place.
        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
        Could use some double checking to see if I'm not doing something stupid .
        Pictures of the boards are attached.
        What I will be replacing with what : (planned)
        Soltek Golden ::
        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
        01-18-2025, 11:44 AM
      • madscientist750
        Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
        by madscientist750
        I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
        07-09-2024, 09:24 AM
      • blues_spirit
        practical courses for troubleshooting pc motherboards
        by blues_spirit
        Hello from France,
        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
        Do you think this is feasible for me? I...
        12-18-2022, 12:56 PM
