AP21X2SG-13 AP21X2MPG-13
    • 115469
    The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
    All AP21X2SG-13 AP21X2MPG-13 devices are available in SO-8 and MSOP-8EP packages.
    Features
    ● Dual USB port power switches
    ● Over-current and thermal protection
    ● 2.1A accurate current limiting
    ● Reverse Current Blocking
    ● 115mΩ on-resistance
    ● Input voltage range: 2.7V - 5.5V
    ● 0.6ms typical rise time
    ● Very low shutdown current: 1uA (max)
    ● Fault report (FLG) with blanking time (7ms typ)
    ● ESD protection: 4.5KV HBM, 350V MM
    ● Active high (AP2192) or active low (AP2182) enable
    ● Ambient temperature range -40ºC to +85°C
    ● SO-8 and MSOP-8EP (Exposed Pad): Available in "Green" Molding Compound (No Br, Sb)
    - Totally Lead-Free & Fully RoHS Compliant
    - Halogen and Antimony Free. "Green" Device
    ● UL Recognized, File Number E322375
    - IEC60950-1 CB Scheme Certified
    Applications
    ● Consumer electronics - LCD TV & Monitor, Game Machines
    ● Communications - Set-Top-Box, GPS, Smartphone
    ● Computing - Laptop, Desktop, Servers, Printers, Docking Station, HUB​
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
    Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
    All AP21X2SG-13 AP21X2MPG-13 devices are available...
    10-23-2024, 03:33 AM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
    G5244 G5244T11U G5244A31U Datasheet
    The G5244, G5244T11U, & G5244A31U are a 120mΩ power switch for self-powered and bus-powered Universal Serial Bus (USB) applications. Several Protection features such as current limiting with foldback, and thermal shutdown are included to prevent catastrophic switch failure caused by increasing power dissipation when continuous heavy loads or short circuit occurs. A built-in charge pump is used to drive the N-channel MOSFET that makes it free of parasitic body diode to eliminate any reversed current flow across the switch when it is powered off. The G5244 has a shutdown discharge function...
    10-06-2024, 03:17 AM
