G5244 G5244T11U G5244A31U Datasheet
    The G5244, G5244T11U, & G5244A31U are a 120mΩ power switch for self-powered and bus-powered Universal Serial Bus (USB) applications. Several Protection features such as current limiting with foldback, and thermal shutdown are included to prevent catastrophic switch failure caused by increasing power dissipation when continuous heavy loads or short circuit occurs. A built-in charge pump is used to drive the N-channel MOSFET that makes it free of parasitic body diode to eliminate any reversed current flow across the switch when it is powered off. The G5244 has a shutdown discharge function when power switch is turned off. User could realize the shutdown discharge function by adding an external resistor between OUT PIN and DSG PIN. Its low quiescent supply current and small package SOT-23-5 and ADFN1.5X1.5-6 is particularly suitable in battery-powered equipment, like PDA, mobile phone.
    Applications
    - High-Side Power Protection Switch
    - USB Power Management
    - USB Host and Self-Powered Bubs
    - USB Bus-Powered Hubs
    - Hot Plug-In Power Supplies
    - Battery-Charger Circuits
    Features
    - 120mΩHigh-Side MOSFET
    - 2.5A of Current Limits with Foldback
    - Operating Range:2.7V to 5.5V
    - 1.9ms Typical VOUT Turn-On Rise Time
    - Under voltage Lockout
    - 65µA Quiescent Supply Current
    - 1µA Maximum Standby Supply Current
    - Active-High Enable Pin
    - No Reverse Current when Power Off
    - Shutdown Discharge Function at DSG Pin
    - SOT-23-5 and ADFN1.5X1.5-6 Package Available​
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
    Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
    The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
    10-23-2024, 03:58 AM
    Richtek RT8205A RT8205B RT8205C Power Supply Controller for Laptop Computer Datasheet
    The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping...
    10-23-2024, 03:37 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
