A deep-dive on TS100.
  • capwizard
    • Jun 2016
    • 1991
    TS100 OLED Programmable Soldering Iron, Ordered from Banggood, received yesterday, after 20 minutes play around, its feels like my PAL, hope not going to be one of my junks.
    A DC connector (DC plug) : DC 5525 is not easy too find over your laptop AC adapters.
    I ordered from here (reference only, always shop around.) : 6Pcs for 99 cents.
    free shipping 5.5mm x 2.5mm DC Power Plugs Male Barrel Connectors Black 6Pcs
    https://www.aliexpress.com/item/free...999.302.JvHPD4
    Product Description
    Description : NEW MODEL TS100 Digital OLED Programmable Soldering Iron Station Built-in Acceleration Sensors with STM32 Chip Embedded Interface DC 5525 2015 New model solder iron station coming! Features : Very easy to replace the solder tip Specifications : Universal power input Interface size : 5.5x2.5mm TS100 mini iron station is an internal heating intelligent CNC soldering iron, lightweight design, easy to assemble or disassemble and storage, comfortable handle, highly effective heating element and simple control interface, Work between DC12-24V, with OLED screen, temperature adjustment buttons, external power independently, up to 300 ? just need as low as 10 sec. Advantage: Based on 304 stainless steel nested polycarbonate housing, integration of safety circuit design power supply interface, anti-static structure, embedded STM32 processor chip, dual temperature sensor and acceleration extreme cooperate, TS100 intelligent temperature control between 100-400 degrees, instantaneous heating, automatic dormancy, over temperature alarm, and other functions. External independent power supply : DC5525 power interface, suitable for notebook DC12-24V power supply, car power and mobile power supply. Micro USB interface: Through edit the parameter file, Additional features: Open source for writting your own App. Package includes : 1 x TS100 Digital LCD Soldering Iron 1 x TS-B2 Solder Tip(Find more types in SKU253283) 1 x Allen Key (For replace the tips and heating element)
    Here are 3 helpful files to you, Could read/download from below.
    >>>>TS100 English User Manual <<<<
    >>>>TS100 Schematic Diagram<<<<
    >>>> TS100 Open Source Code<<<<
    http://www.banggood.com/TS100-Digita...tml?rmmds=cart
  • capwizard
    • Jun 2016
    • 1991
    Re: A deep-dive on TS100.
    Hardware: I study each IC by myself.
    U1 SGM8551XN : Single-Supply, Single Rail-to-Rail I/O Precision Operational Amplifier.
    https://cdn.badcaps-static.com/pdfs/...65384ebfbe.pdf
    U2 RT7272B : 3A, 36V, 500kHz Synchronous Step-Down Converter.
    U3 MMA8652FC : Freescale Semiconductor, 3-Axis, 12-bit, Digital accelerometer. Pic 3
    U4 STM32F103T8U6: Medium-density performance line ARM-based 32-bit MCU with 64
    or 128 KB Flash, USB, CAN, 7 timers, 2 ADCs, 9 com. interfaces ARM® 32-bit Cortex®-M3 CPU Core
    https://cdn.badcaps-static.com/pdfs/...e2440eba90.pdf
    U5 CX6206-3.3V: a CMOS step-down voltage regulator with high ripple rejection, low power, low dropout, overcurrent and short circuit protection. These devices have very low quiescent bias current (8.0μA Typ.) Which can deliver 250mA output current with very small input and output voltage differences, Output voltage: 1.2V-5. 0V (steps of 0. 1V), High precision output voltage: ± 2%, Low temperature adjustment factor.
    U6 TMP36GRTZ: Low Voltage Temperature Sensors.
    https://cdn.badcaps-static.com/pdfs/...02981bb424.pdf
    • capwizard
      • Jun 2016
      • 1991
      Open source software.
        • 31246
        nice.
        • capwizard
          • Jun 2016
          • 1991
          Another adult toy, after you put a battery pack.( portable microcontroller battery powered iron)
          Use 4 x 18650 = 16.4v, work really good with TS100.
          Better 18650 Battery Holders
          https://www.youtube.com/watch?v=euNRqVOH580
          DIY Storage Box Battery Case Holder for 2 X 18650 Batteries 3.7V Rechargeable Battery 4 Pin Black.(reference only, always shop around.)
          https://www.aliexpress.com/item/DIY-...608.0.0.NEDFQQ
          • capwizard
            • Jun 2016
            • 1991
            All I try to doo the experiment is will cheap T12 tips can put inside TS100 for daily abuse use and save $.
            PS: I ordered T12 tips is on the way, will update.
              • 31246
              i was wondering about that.
              wattage shouldnt be an issue - fets can be upgraded,
              but i wonder if the sensing will be too far out.
              • redwire
                • Dec 2010
                • 3912
                It looks like great tech but kinda fail on ergonomics - nothing to stop your fingers from sliding onto the heating element! Unlike every other soldering iron ever made. Sigh
                • capwizard
                  • Jun 2016
                  • 1991
                  I thought about that I try to put black silicone or high temperature red silicone over there of which for handle comfortable touch and stop sliding onto the heating element at same time.
                    • 31246
                    just put a thin washer between the tip & handle.
                    1mm difference shouldnt stop it connecting internally.
                    • capwizard
                      • Jun 2016
                      • 1991
                      Open source software and hardware will be wonderful tools for school kids to study. I think this is a breakthrough put a microcontroller inside hand-hold soldering iron. The next step will be voice commands and wifi to your iphone...
                      PS: I try to add a LED which can light up the tip.
                        • 31246
                        no, next step is to make it into a small case w/psu like the bakon bk950d
                        then plug your T12 based $10 iron into it - job done
                        • capwizard
                          • Jun 2016
                          • 1991
                          One repair job paid for (TS100) itself. Customer is a DJ, needs his PC, the power switch broken, 2TB music inside, needs today. I said no time for parts order, if you don't mind, I will put a switch for you. The solder job is smoothly finished.
                          • capwizard
                            • Jun 2016
                            • 1991
                            Best tips I ever got, is From Mr.Sti, just put a thin washer between the tip & handle. 1mm difference shouldnt stop it connecting internally.
                            Solve the solder tip to close to table problem, at meantime change HEX to Phillips screw .
                            • capwizard
                              • Jun 2016
                              • 1991
                              Prepare to return if.....
                                • 31246
                                so why is it stripped??
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  I didn't cut it open.................
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    last picture show lines is the camera problem, LG Stylo 2 PLUS 1080p camera used,
                                    NO!! is the OLED I did not put in right position, and Polarizing filter film show the lines, but my eyes show was A good display. i FOUND the technology of how LCDs work on polarized light. I mean OLED=LCD same display technology.
                                    Thats OK I will correct this problem next time.
                                    PS: Ive fixed the bended TORX screwdriver, by heated the tips.
                                    Should I return??? NO, I learn a lot, love even more on this pre-open TS100 than my wife.
                                    This theftproof TS100, I could take a picture and show that was mine.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      k-type temperature sensor circuit is kinda confuse will completely explain at tomorrow.
                                        • 31246
                                        i have found the official forum with firmware updates etc.
                                        http://www.minidso.com/forum.php?mod...display&fid=67
