Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Old 05-21-2008, 07:41 PM   #1
i4004
i4004's Avatar
City & State: Hrvatska, Dalmacija
Default Asus P5P800-vm with blown 9T15GH fet
as seen on these pix. it's all i can see.
symptoms were: smoke smell, no video, fans spinning ok, hdd light on all the time...
and those chemicons look shaken.
anybody seen this before? i've found some info on russian forums, but that was it. searching usually finds only asus boards with this issue. and not much of it anyway(seems to be a rare problem).
how to explain it? marginal quality part? chemicons? bad design overstressing components?
what's weird is that these are not usual cpu supply issues, but north bridge, it seems(if agp is offline).
this french thread talks about replacements
http://forum.hardware.fr/hfr/Hardwar..._702508_11.htm
(AMP3054N or STD17NF03L)
you can try this to tranlsate
http://translate.google.com/translate_t?sl=fr&tl=en
i4004 is offline   Reply With Quote
Old 05-23-2008, 04:00 PM   #2
zandrax
Hit and miss
City & State: Trento
My Country: Italy
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
Default Re: Asus P5P800-vm with blown 9T15GH fet
The regulator near KZG caps seems burned (black spot): is it burned or is a compression glitch?
Zandrax
Have an happy life.
zandrax is offline   Reply With Quote
Old 05-23-2008, 06:22 PM   #3
i4004
i4004's Avatar
well, if it was a compression glitch, this thread wouldn't have words like
"blown fet", "smoke smell", "no video" in it...
<wink>
yes, burned, and seems like a most probable cause for this system not producing any video, be it onboard, or inserting some agp card...
it was overheating, and now it stays rather cold..hehe...
notice the swallen chemicons: they should look like the one that is just right to the ram slots...
here's another mentioned replacement for this fet
http://monitor.net.ru/forum/asus-p5n...nfo-75162.html
(90N02 (можно 60N02, 70N03 и т.д.))
here's one more report
http://monitor.net.ru/forum/asus-p5r...fo-198107.html
overall, it seems to be rather rare malfunction...
i need to check if any of those replacaments are available here...
Old 05-24-2008, 05:05 PM   #4
zandrax
Hit and miss
My Country: Italy
<wink>
[cough] Sorry, my mind get easily rid of post titles.
I didn't caught you already found a blown fet so I pointed it out.
Tried with a PCI card?
I hope you can find one.
Zandrax
Old 05-24-2008, 06:16 PM   #5
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
that is a vdimm reg.
bad ram,or improper insertion causes this.
kc8adu is offline   Reply With Quote
Old 05-24-2008, 07:01 PM   #6
i4004
i4004's Avatar
yes, that's a possibility: there were some problems prior to this that looked like bad ram...machine stop bsod type of thing...
