Intel D865PERL caps
  • splur
    • May 2014
    • 9
    Intel D865PERL caps
    So I have a bunch of computers with D865PERL mobos which all have similar caps that have either buldged or burst. Their ages match perfectly with the bad batch of Nichicon caps that were supposedly overfilled and burst prematurely. Unfortunately, given the age of these boards, it's not obvious what the replacement would be for these caps. Suggestions on good equivalent replacements?
    The caps (had to tape measure the dimensions so they may be rough):
    Nichicon HM(M) 2200uf 10V ~10mm(d) x 22mm(h)
    Nichicon HN(M) 820uf 6.3V ~8mm(d) x 20mm(h)
    I'm thinking http://www.digikey.ca/product-detail...MPD-ND/2428109 for the 820uf although the dimensions seem different (much shorter at 8mm), the ripple current seems okay? I'm totally lost for the 2200uf, I can't even find specs on these guys or ones with similar dimensions.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Intel D865PERL caps
    You gotta get rid of all Nichicon HM and HN caps on those boards - they will all fail. You can use new Nichicon HM and HN as replacements - these don't have the same defect that the old ones did. Here are some suggestions:
    for the 6.3V 820 uF HNs:
    https://www.badcaps.net/store/produc...products_id=76
    for the 2200 uF 10V HM:
    https://www.badcaps.net/store/produc...roducts_id=168
    ^Don't worry about the lower voltage rating on that one. There can be no more than 5V on that cap.
    for the 1200 uF 16V HMs (visible in your second picture and these weren't on your list):
    https://www.badcaps.net/store/produc...roducts_id=174
    Or if you really rather buy from Digikey, let me know.
    • c_hegge
      • Sep 2009
      • 5219
      Actually, the 1200uF 16V caps are, in all likelihood, Nichicon HD, which supposedly didn't have the defect. They -should- be OK to leave in place.
      • splur
        • May 2014
        • 9
        Thanks a lot for the reply and information, I was totally lost about these older boards. Preferably I would go Digikey, ideas on equivalents? I've looked and it seems they've discontinued exact models. If it is a total mess finding equivalents for those two capacitors then I have no issues going through badcaps.
        Phew, it's good to know that not all the capacitors on this board (actually there's 4 boards) aren't completely shot. May order extras in case of future issues.
        • c_hegge
          • Sep 2009
          • 5219
          For the 820uF 6.3V caps next to the CPU, you can safely use 2.5V polymer caps, since they are on the CPU VRM Low side, and won't be dealing with voltages higher than about 1.5V. You could use these as a replacement - http://www.digikey.com/product-detai...4CT-ND/4204369 (Sanyo OS-CON SEPC 820uF 2.5V)
          For the 2200uF 10V Nichicon HM, there isn't an exact replacement, but a Panny FR would -probably- be close enough (http://www.digikey.com/product-detai...382-ND/2433516)
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            The Sanyo SEPC are great caps! There are some other good polymer and functional polymer choices, though, like:
            Fujitsu FPCAP - RR5, RE5, RR7, RE7, RL, and RS
            Chemicon PSC and PSA
            Below are some links to look at.
            Here's something more or less equivalent to the SEPCs in terms of endurance, but a little cheaper:
            http://www.digikey.com/product-detai...1-1-ND/2347896
            http://www.digikey.com/product-detai...337-ND/4204173
            http://www.digikey.com/product-detai...328-ND/4204164
            cheapest (but still good quality polymers, just lower endurance at 105C):
            http://www.digikey.com/product-detai...685-ND/2203554
            http://www.digikey.com/product-detai...690-ND/2207225
            http://www.digikey.com/product-detai...219-ND/1826683
            http://www.digikey.com/product-detai...3057-ND/758488
            For the 2200 uF Nichicon HM, this is almost an exact replacement (just slightly lower voltage) and a bit cheaper:
            http://www.digikey.com/product-detai...MPD-ND/2428123
            Or these will do as well:
            http://www.digikey.com/product-detai...MPD-ND/2428110
            http://www.digikey.com/product-detai...2344-ND/613705
            http://www.digikey.com/product-detai...744-ND/4289597
            http://www.digikey.com/product-detai...805-ND/3664445
            (the caps in that last link are Nichicon HW - these are new series that I never tried before, so I don't know how good they are, but they appear to be equivalent to Panasonic FR/FM).
            Good catch. Totally forgot these were indeed present on some motherboards.
            • mockingbird
              • Dec 2008
              • 5488
              You might consider replacing all the little Nichicon VR on the board too. It's not a very long-lasting series, and Intel liked to use them on their boards.
              • c_hegge
                • Sep 2009
                • 5219
                Nichicon FPCAP - RR5, RE5, RR7, RE7, RL, and RS
                FTFY. Nichicon owns Fujitsu's capacitor division now.
                • splur
                  • May 2014
                  • 9
                  Thanks all for the help, youre suggestions worked out well momaka. I was scared at first about going from 10V to 6.3V, first time I went with capacitors of slightly different specs.
                  Anyways, ended up going with Panasonic 2SEPC820MY and Nichicon UHN0J222MPD. Had more troubles figuring out the software issues that came from me resetting the CMOS than the actual desoldering and soldering the new capacitors in.
                  • neumannu47
                    Funny Guy
                    • Jan 2008
                    • 26
                    What sort of equipment are you using to desolder caps from motherboards?
                    • splur
                      • May 2014
                      • 9
                      A 30W soldering iron, although I was limited in this case, typically I'd try and get a 40W... and my precious fingers to pull the caps off once I've heated the joints. Crude but effective.
                      I use a manual pump to clean the holes and a desoldering wick for anything left over.
                      • neumannu47
                        Funny Guy
                        • Jan 2008
                        • 26
                        Are you using an 800 degree tip? My 700 degree tip does NOT do well with the lead-free solder on motherboards.
                        • splur
                          • May 2014
                          • 9
                          I actually couldn't find the specs for the soldering iron, and it's fixed temperature so not sure what temperature the tip is.
                          I did have trouble at first though, mixing in a bit of new solder helped melt the old solder and the caps came out no problem.
                          • nick3092
                            Mid/late 80's Nichicon Yellow Caps
                            by nick3092
                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                            08-28-2022, 03:56 PM
                            Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                            by momaka
                            I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                            For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                            https://www.badcaps.net/filedata/fetch?id=3591771
                            https://www.badcaps.net/filedata/fetch?id=3591772
                            It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                            https://www.badcaps.net/filedata/fetch?id=359177...
                            03-12-2025, 03:42 PM
                          • eryjus
                            Heathkit IO-4205 Power Supply Caps
                            by eryjus
                            First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                            I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                            I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            Identifying caps on an old Zoom 9000
                            by Paxman_Swede
                            Hello!
                            I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                            The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                            I have studied the board and...
                            01-14-2025, 09:51 AM
                          • captain150
                            Help with switching power supply caps
                            by captain150
                            I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                            I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                            03-16-2025, 07:34 PM
