I have a Jetway Versa J7F4K1G2E motherboard. It has mostly polymer capacitors, but there are also some 220uF and 100uF CapXon electrolytic capacitors on it. They are in one of the coolest areas of the motherboard (it stays about room temperature there) and seem to be on the +5V, +3.3V, and +5VSB rails. I also have a high quality PSU. I was wondering if I should be worried about these capacitors failing.
Should I be worried?
Re: Should I be worried?
If it gets erratic replace them.
.Mann-Made Global Warming.
- Dr Seuss
Originally posted by cheapie View PostI have a Jetway Versa J7F4K1G2E motherboard. It has mostly polymer capacitors...
The reason I ask is because Jetway has often used GSC/Evercon/Sacon capacitors in the past (and I wouldn't be surprised if they still do). These 3 brands (or rather 1 really) have been known to fail consistently.
Sacon capacitors in particular have a specific series - the FZ - that are known for their "polymer" looks. In fact, they are just regular eletrolytics caps (and very bad ones at that). If you see a vent on your "polymer" capacitors and the letters "FZ" printed on top, then you have Sacon FZ. Those should be replaced on sight.
Agree.
Jetway likes FZ.
BTW: FZ come marked with either blue or black ink.
Printing and sleeves are just marking methods.
Neither one tells you if a cap is polymer or lytic.
They both come marked both ways.
- Dr Seuss
They don't have any vents. Some are marked "FP 98Ab 122 04" and others say "FP 99Ae 471 6.3". The ink is red.
Here are the possibly polymer capacitors:
(the larger ones are "98Ab" and the smaller ones are "99Ae".
And here are the CapXons:
The FP is the -logo- for FPCAP brand which are Functional Polymers.
Used to be owned by Fujitsu, now owned by Nichicon.
Good caps. - Leave them alone.
The 122 04 = 1200uF 4v
The 471 6.3 = 470uF 6.3v
FZ are a series of Sacon. I don't see any.
When I said "If it gets erratic replace them" I was talking about the small Capxon.
To modify that: If they are 6mm or larger I might replace them anyway.
[Particularly if any are near the chipset.]
.Last edited by PCBONEZ; 12-29-2011, 07:53 AM.Mann-Made Global Warming.
- Dr Seuss
The Capxons in the last picture are most likely used by the integrated sound card and network card... if you get crackling in the sound or the network disconnects often or has poor performance, maybe capacitors would be the cause.
Otherwise, I don't see them under enough stress to have issues so I don't think you should change them.
Originally posted by cheapie View PostHowever, the sound hisses quite a bit, but it did that right out of the box.
For most of those Panasonic FC should be enough.
Check the specs to be sure.
Originally posted by cheapie View PostAlso, I have another device that has capacitors marked "B1 47 25V" and "47 VFK. 1W5". Are these good caps?
Will have to be a bit better photos than those first two.
- Dr Seuss
