Another Viewsonic VP201 repaired thanks to badcaps forum!
    A co-worker gifted me with a broken Viewsonic VP201 LCD display. The power light was green, but nothing appeared on the display. A google search using its model number and "repair" brought me to the badcaps forum thread 95163.
    Upon disassembly I found 1 bulging 680 uF 25V cap and an open F2 fuse. I measured 17.75V from the power supply.
    I ordered a complete cap set and fuses from Mouser.
    Last night I replaced both 680 uF caps (Ltec), and the 150 uF 400V (Taicon) high side cap, as they were the only ones with China/Taiwan origin. I left the Nichicon 22 uF and 47 uF's alone, mostly because I didn't feel like digging them out of the white adhesive goop. Then I replaced the fuse - my first surface mount PCB repair.
    I reinstalled the power supply board, inverter board, and the inverter shield then applied power to the panel. The "No signal" icons appeared - the first sign of success! PSU output voltage was still 17.75V. I reinstalled the main board and power supply shield, then buttoned up the case. Connecting it to the computer confirmed its successful resurrection from the dead.
    Some Mouser part #'s for your convenience:
    576-0466002.NR 63V 2A Littlefuse
    647-UPZ2G151MHD6 400V 150 uF Nichicon aluminum electrolytic cap
    667-EEU-FR1E681 25VDC 680 uF Panasonic aluminum electrolytic cap
    Thank you, badcappers Wrog and PlainBill, for making this an easy fix.
    Jon
    Re: Another Viewsonic VP201 repaired thanks to badcaps forum!
    Thanks for Posting this with the part numbers, I have a VP201 that powers on for about 10-15 minutes then goes dark. Turn it off for a while to cool down an it comes back to life for a short period. Looks like the culprit is a bulging 150uf 400v cap on the power supply board. The board shows signs of heat (browning) around this cap as well. Hopefully replacing it will solve the problem.
      I dont know your background but would advise care in desoldering in this area.
      The cap can hold a charge of up to 400volts in the us perhaps 260volts.
      If it is faulty it may not discharge correctly.
