hi to all here i just want to ask if any 1 can help me to find schematic for this model and if any 1 can help me to fix this laptop its dead cant charge the battery cant even power on its some kind of spilled of liquid in keyboard...thanks in advance here is the detail of mobo DA0ZR7MB8F0 Rev:F hannster J MV-4 94V-0
Acer aspire 5745DG power problem plz help!!
Re: Acer aspire 5745DG power problem plz help!!
Originally posted by spidey View Poststart cleaning the board using alchol, then start measuring coils. Also it would be great, if you could measure the current.
to check the current, connect your multimeter serial to power plug in (DC) A mode. You should see 0.01A while in standby mode. if it is higher than 0.003A, that means there is problem. Btw, check +3v +5v circuit coils, to see +3.3v and +5V exists. then measure on/off button if there is 3.3v, and press the button, is it going down to 0v ? Also check cmos battery. You have some voltages on caps so you dont need to worry about fuse. Btw it should be around power plug.
Originally posted by spidey View Postto check the current, connect your multimeter serial to power plug in (DC) A mode. You should see 0.01A while in standby mode. if it is higher than 0.003A, that means there is problem. Btw, check +3v +5v circuit coils, to see +3.3v and +5V exists. then measure on/off button if there is 3.3v, and press the button, is it going down to 0v ? Also check cmos battery. You have some voltages on caps so you dont need to worry about fuse. Btw it should be around power plug.
Originally posted by spidey View PostAre you sure, you are japan ? ok, switch your multimeter to DC Current (A) mode, cut the power adapter (+) cable, then connect your probes to cable serially. Btw you must connect probes to correct place on multimeter. is it clear now ?
PS: sorry for not updating any progress
Originally posted by bushido View Postits been a long time...im here again to ask for your help!! i never done fixing this laptop if any one here have a good heart willing to teach me or help me to fix this dead laptop just like spidey did i really thank you..
I have myself had a keyboard spillage that killed a laptop dead until I removed keyboard and up it started, then I just had to buy new keyboard
good luck
Originally posted by teqbizz123 View PostI have the same problem with my laptop it works four Six hours then it turns off
good! mine can only go for 5 hours it heats up or blue screen cuz you know its windows?Just cook it! It's already broken.
Hi guys sorry for posting this up on this thread but i need help ....
I am trying to fix an emachines D440 with AMD v120 Processor and ATI Radeon HD 4520 it switches on and takes about 0.96A and does not display. I did BGA on on the IGP but still the same no changes. anyone got ideas.
please HELP..
Originally posted by mtherana View PostCorrection: Sorry I meant BGA Reflow on the Radeon IGP 1020.
a. if voltage reading is missing, you have your clue.
2. Measure pin 22 of mini card WLAN if you get 3.3v when powered on. if this is missing check the ICH/PCH/Southbridge.
post what your results.
Originally posted by whaldsz View Post1. Try measuring the voltages across the big capacitors first, see everything has the correct voltages.
whats the condition of missing?
No voltage only if adapter its in without pressing power button?Just cook it! It's already broken.
