I have a little power supply and the terminals i have dont fit, i got #10, #8 and #6, i think i need a #12 if they exist but i cannot find them at all. The connectors are very tight together.
Fork terminals for led power supply
Re: Fork terminals for led power supply
How big is the screw stud is this? #10 stud is pretty big.
1/4 inch stud?
http://www.amazon.com/Gold-Spade-Cri...ords=spade+lugLast edited by budm; 04-30-2014, 11:02 PM.Never stop learning
Lol i went backwards, so confusing with wires its larger is actually smaller i mistakenly thought it was the same for terminals
I think i need a #4, the PSU i have is similar to this
http://www.ebay.com/itm/New-24V-2A-D...item58ab50edfe
Those terminal block in that size is usually #6 screw.
BTW: Most terminal such as AMP, the Yellow jacket is for 10~12 AWG wire, Blue is for 14~15 AWG, RED is for 18~22 AWG wire.
The spade lug comes with many width also for the same stud size.
For example, this one is 0.320" wide:
https://cdn.badcaps-static.com/pdfs/...833c54d985.pdf
This one is 0.300"
https://cdn.badcaps-static.com/pdfs/...959c64639c.pdf
So make sure to get the correct width that it will fit into the terminal block.
This one is 0.250"
https://cdn.badcaps-static.com/pdfs/...ef86aa1e40.pdfLast edited by budm; 04-30-2014, 11:48 PM.Never stop learning
