How the hell do I get into the bios on this board? It refuses to let me, I am using a usb keyboard, don't that if that will mean anything, the manual says the delete key, but it absolutely refuses to let me into the bios. I even tried ALL of the f-keys.
Supermico X6DAL-G bios problems
Re: Supermico X6DAL-G bios problems
use a PS2 keyboard. mine does the same thing.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
how much RAM did you end up putting in this system?<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Originally posted by ToastyOther than scratched, broken, melted, how does a CD go "bad"? Try another player perhaps?<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Admittedly I've HEARD of people having those problems, but I've never experienced it after 15 years of burning them. I've bought some real junk CD's also. The 100 stack for $20 kind of deal.
I have them not burn correctly, but that is usually my fault for allowing them to burn at the "rated" max speed of the drive. I learned to back it down long ago to no faster than 2/3rd's rated, and never have had a problem since.
Curious indeed...veritas odium parit
I learned to use only premium brands: Verbatim, Maxell, TDK in descending order of preference.
Several of my 12" LaserDisc have rotted out. A real shame, as those titles are out of production. This was a real problem with LD, but I suspect internal meltdown is probably a factor for CD and DVD media also.
I tell all my clients that CD/DVD are *not* archival media, and to make multiple copies.
Originally posted by 370forlifeThe cd is a "cool burn" (no, you don't use it if you get burnt)
I wound up putting 2 gigs of ddr-266 ecc registered in it. 4x512mb modules, ATP brand, but the memory chips themselves are samsung.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Might as well put 64 on it now to support extra ram in the future. Most of the time it will be hosting a cod4 server and running cod4 at the same time (has a 8600gt in it)
Im still not even completely sure if these processors are 64 bit support, I believe they are sl7dx's.
