Hard drive from a pvr
Re: Hard drive from a pvr
I have a sky hd hdd (500gb) and a virgin tivo hdd (500gb) in my pc and they both worked fine after going into disc management and converting them to Basic discs. These are 2 of the major players when it comes to encryption and stuff so you should be able to get your one going.Do NOT touch heatsinks when testing for voltages as they may be LIVE!
I'm sorry but I think that won't be easy to unlock that drive.
MHDD can unlock the drive only if you know the password but
can be used to see if the security mode is High or Maximum
by pressing ALT+F2.
According to this
http://en.wikipedia.org/wiki/Paralle...s_and_security
it's possible to unlock a drive locked in high security mode issueing the MHDD
DISPWD command and providing a master password, but if security mode is
Maximum you can only Secure Erase the drive with a master password.
You can use this http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml
but you have to hope that the default master password has not been changed.
I found this http://ipv5.wordpress.com/2008/04/14...ter-passwords/
but i don't know if seagate had used different password for that drive family.
Secure Erase it's a built in fuction of the drive that completely delete
any sector of the drive and may take a very long time to complete, and,
if the drive is internally damaged may not end at all...
A better and quick way to unlock the drive would be to use some professional, and very expensive tool such as PCI3000, in many case it just requires few mouse clicks to complete the job.
Such tools do basically what OniJon suggested to do, but his hint works only
on some Western Digital drive, by rewriting a module of the hard disk firmware
where the password is stored; things works differently in seagate (and in other brand) drives.
http://forums.seagate.com/t5/Barracu...eft/td-p/47233
http://www.msfn.org/board/topic/1556...erial-console/
lots of info can be found on hddguru.com, but this is a forum for professional
so few valuable info will leak.
best regards.
Originally posted by noppa View PostI forgot you may try to get some info from the maker of the PVR,
since the password is sent to the disk by its firmware it has to be there.
Dont give up yet, if 9200 is anything like 9242 or 9241 you can do this as I can confirm it works.
Code:How to activate VIP Hard Drive for general mounting The drive is shipped in "power-up in standby" mode So, the drive is a paper weight until the ATA driver can spinup the drive from standby mode and unfortunately kernels prior to 2.6.24 cannot handle these drives without patching. If you have a linux distribution with kernel less than 2.6.24 you may want to download patches and the hdparm from here hxxp://superb-east.dl.sourceforge.net/sourceforge/hdparm/hdparm-9.11.tar.gz More info from the manpage of hdparm Code: -s Enable/disable the power-on in standby feature, if supported by the drive. VERY DANGEROUS. Do not use unless you are abso- lutely certain that both the system BIOS (or firmware) and the operating system kernel (Linux >= 2.6.22) support probing for drives that use this feature. When enabled, the drive is pow- ered-up in the standby mode to allow the controller to sequence the spin-up of devices, reducing the instantaneous current draw burden when many drives share a power supply. Primarily for use in large RAID setups. This feature is usually disabled and the drive is powered-up in the active mode (see -C above). Note that a drive may also allow enabling this feature by a jumper. Some SATA drives support the control of this feature by pin 11 of the SATA power connector. In these cases, this command may be unsupported or may have no effect. So, the PIN 11 is missing on the SATA Power connector in the VIP boxes On a linux > 2.2.24 system with a normal sata power cable you can just mount the drive without doing anything. You can disable "Power Up in Standby Mode" with this Code: hdparm -s0 /dev/sdc on my box its /dev/sdc - it could something like sdb or some thing else run Code: fdisk -l to find out. I dont think this is a security feature but has to do with initial power draw during power up
