Hi, I was looking for information on the problem I'm having and there seems to be a lot of knowledgeable and helpful people in this board.
The monitor is a Samsung Syncmaster T260, it started doing this when it was about two years old and has been getting worse in the past three years, in the beginning it would only be sporadically, now it does it daily. The power supply is the IP-54155A.
Setup:
The monitor is either plugged via DVI to a 2007 mac mini or to a macbook via HDMI. I have 5 outlets behind the desk and the monitor is the only device that fails, no mater where I plug it.
The symptoms:
I have read a lot of post about the "2 sec to black" problem but those monitors don't turn off completely, just the back light.
Do you think it could be a power supply capacitor problem? The ridiculous "touch" on-off switch? Or the main logic board (in which case, there isn't much I can do).
Thanks in advance for any ideas. i have a multimeter if you need me to check something but it only have the basics: Ohmmeter, AC/DC voltage/current, transistors and diodes.
UpdateI forgot to mention that I measured the secondaries of the inverter, both windings are around 1K with very small difference between them, I don't have the exact value here.
Update 2It is a 26", I uploaded a pic of the model # and the rest of the boards:
Main logic board: it has all the ports, everything looks clean, I did a close up on the corner where the power connector comes in.
There is also a small board that manages the led, side buttons and the "touch" sensor.
The pictures: The board was this clean when I took it out. I don't see bulging on the caps and the pcb around the high tension components is not brown or toasted. Is one of the cleanest board I have seen.
Setup:
The symptoms:
- The monitor will completely shut down sometimes after an hour, sometimes after 30 mins. The screen goes black and the led turns off. If plugged to the macbook the computer stop recognizing it.
- Sometimes it will turn on again by itself after a second, sometimes it would need me to "touch" the switch to turn it on. Is intermediately recognized by the macbook when it comes on.
- On a good day it will fail two or three times during the whole day day.
In a bad day it will come on again almost instantly but then it will turn off a few minutes later. On a bad day it wont turn off at all after the first glitch (nor the led or the screen that is).
