Longtimers
    Longtimers
    Back several months ago I received a Dell 1801FP monitor. I put it up because I had several other projects going. Today I got it out to work on it. I previously found a thread on it and read about a solution to my problem. Now I can't find the Thread.
    Now that I have been around awhile I know to subscribe to a Thread, but that does solve my problem today. I have searched the entire Monitor Forum with the search feature and can't find any mention of this monitor. Is there some way to search inside of Posts for this monitor? I searched on Dell 1801FP and 1801FP and just plain Dell. I scanned through all the Dell Monitors that came up on the search with no luck.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    Re: Longtimers
    Perhaps you can search under the model number of the power supply. Many different brands of monitors use the same power supply.
      Re: Longtimers
      SellDoor thanks for the postings. Neither one of the first two were actually about the 1801 there was just a mention of it in each thread. Your right about the two boards being different. They are totally different as one has backlights on it and the other does not. I have repaired an 1800 got it working and used it for two weeks. Finally sold it on ebay. Thanks for the help.
        Re: Longtimers
        I will try that, thanks for the suggestion.
          Re: Longtimers
          use google to search site if in sight one does not give ya thread ya looken for.
            Re: Longtimers
            Thanks tried that, no luck.
