diode search
    diode search
    Hi folks
    I have a Optiquest Q9B2 That goes black after 15 seconds all caps test very
    good on my esr meter. I testing 2 diodes on the inverter side and found voltage going both ways
    diodes have SR240 upm can not find them all I find is
    SCHOTTKY DIODES SR240 is this the same? how would I find out correct amps and volts for new diodes.
    Re: diode search
    Hi - dont really understand the question Does the marking on your diode say SR240upm
    and you cant find that or you cant find one to buy
    SR240 is as you say a shottky diode it is rated at 2 Amp 40 volts hence the name S R 2 40
    A picture would have helped - does it look like the one in this datasheet
      Re: diode search
      Yes it is, here is a picture I am also wondering about the letters upm or
      should I just order sr240 I am also having trouble finding a supplier That in the US
      Thanks selldoor
        Re: diode search
        This one at digikey looks like it will do the job
        http://www.digikey.com/product-detai...3-1-ND/2075777
          Re: diode search
          Thanks selldoor
