Westinghouse L2610NW
All caps are chemi-con KY.
EDIT: I LIED, all the big caps are KY the small 50v 47uf and less are taicon. Bad startup cap?
When the monitor is cold, it turns on fine and every time too. But after having it on for few hours, if you let the monitor go into standby then later wake it within 5 minutes the backlight kicks on for 2 seconds then goes out. You can still see an image but the backlight nonfunctional. If you turn it off and back on immediately it still goes out, but if you wait a good 5 or 10 minutes you can turn it back on without issue.
I can't tell if I have bad ccfl or a faulty component as a result of heat.
Is it possible the caps are bad?
There is some discoloration on the board around the small caps near the inverter?
