Good day folks. Pretty simple task at hand here, so go ahead and laugh at me if your want, but only if you also provide a bit of help I need to step down a 12Vdc supply from a power adapter to 9Vdc to power up some wireless routers I found in our box of trash at work despite being functional. Before you say I should just get a 9v adapter or a 7809 regulator, hey where's the fun in that ? People like me like to make things more complicated than they should be just for the sake of learning stuff, so I decided to learn more about linear regulators by building one myself. The final product does not require too high a build quality and precision, since it's just about powering some crap devices which at the end of the day I'm sure would run just fine if I were to power them with the 12v directly, but I don't really wanna do that. So I was thinking of building the simplest linear regulator possible with a transistor, a zener diode and a resistor. I know what a linear regulator is and what it does and even had the schematic in my mind, but the problem is the actual choice of parts I should use. At this point I could've just sourced the exact parts used in one of the many examples I found, but I didn't actually want to BUY anyhting for this project, so I rummaged through my box of transistors and picked the one with the highest current rating I found (1A), the S8050 (datasheet here), since that's what the router requires. I also got myself the C9v1 zener diode (datahseet here). Now it's time for the resistor and this is where I ran into a bit of trouble and got tangled up in numbers and calculations and formulas, all of which I suck at unfortunately, so please bare with me as I'm an absolute disaster at math. Here goes nothing: good ol' Wiki tells me that I should use this formula to calculate the value of the resistor I should place between the base of the transistor and Vcc (12v)....after trying my best, I ended up with a value of 2500 Ohms, which is probably wrong, so let's run through the formulas together like in second grade and see what we get: so
*Vs-Vz is 12v-9v (let's keep it round) = 3
*Going below the fraction, I tried figuring out what Ibase should be for that 8050 I chose. The wiki article tells me Ib is equal to Ir2 divided by the hFe of the transistor. The router (which is the load R2) requires 1A, divide that by the minimum hFe which the datasheet tells me is 40 and it equals 0.025.
*Now, what's the deal with that K ? Is it like a constant ? The wiki article just tells me it should be between 1.2 and 2....ok, I'll just pick 1.2 I guess, so 1.2 times 0.025 (Ib) = 0.03
*Ok, assuming everything so far is correct (which is probably anything but) I then hit the first hurdle: Iz, zener current...what is this ? Is it the maximum current the diode allows ? If so, the datasheet gives me 43mA (which would be 0.04A ?), so we add that to the formula and we get 0.04+0.03 = 0.0012
*3 divided by 0.0012 gives me 2500....2.5 kOhms ? Was I even close ? Again, my main point is not so much to get the damn thing to work, as that could easily be solved , but to learn about stuff which lies dormant in the back of my head.
