Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 02-17-2017, 01:09 PM   #1
Half-Saint
City & State: Idrija
My Country: Slovenia
Line Voltage: 220V 50Hz
Default Voodoo 3 missing two capacitors
I'd like to identify two small capacitors that were broken off before I got it. The card sometimes works but most of the time doesn't output VGA signal. I'm hoping replacing the caps will fix this.
There's one left and the markings are:
10
16S
0G2
I'm guessing that this means 10uF, 16V. No idea about 0G2.
Would this be a suitable replacement?
http://si.farnell.com/wurth-elektron...rfnonsku=false
Half-Saint is offline   Reply With Quote
Old 02-17-2017, 03:44 PM   #2
Drack
Badcaps veteran
Drack's Avatar
City & State: Backyard
My Country: Venezuela
Line Voltage: 110v 60hz
I'm a: Student Tech
Default Re: Voodoo 3 missing two capacitors
If they were really small probably 10uf 16v as you said, 0g2 looks like a code, something to do with the date or batch who knows, do you have any pics?
Drack is offline   Reply With Quote
Old 02-18-2017, 12:04 AM   #3
Half-Saint
Yes, they are really small. No pics, smartphone camera sucks and I don't have time to take a proper photo right now.
Old 02-18-2017, 07:20 AM   #4
Drack
Badcaps veteran
Drack's Avatar
I'm a: Student Tech
If the size is the same those that you listed from farnell should work
Old 02-18-2017, 09:21 AM   #5
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
There are pictures of many different "voodoo3" cards here http://hw-museum.cz/collection-vga.php?type=3dfx you should be able to see which cap's are missing and their values, the last 3 letters are likely date codes. If the missing ones are the same size as one thats still on the board, you can measure it for the correct size.
R_J is offline   Reply With Quote
Old 04-09-2017, 10:39 PM   #6
Half-Saint
I took the caps from another voodoo 3 board but that still didn't fix the board.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
