Right... Killed this motherboard myself by shorting it out. I run my system as a bench rig as I am swapping out GPU's constantly to test after reballing. I switched my motherboard out for another after a socket replacement and while the area was empty I placed a CMOS battery down.... forgot about it and reinstalled the Asus Crosshair.... Switched it on to be met by a spark and system shut down (Battery touched underside of the board near the USB ports)
Now when attempting to power on if i press the power button repeatedly every now and then the LED's all illuminate on the board and the PSU fan twitches for a split second.
All fuses on board check fine
Removing the 8 pin 12v connector make no difference
How do I go about diagnosing the issue?
Cheers
Cheers
