Hi, I have an ACER Aspire 5535/5235 series laptop which switches on but no display. Suspecting that the ATI IGP chip needs reflowing on the motherboard (48.4K901.021) I disassembled and did that. Now, I'm not sure if I shorted with something during installation but now when I switch it on it does switch on just like before but with smoke coming off near the AMD CPU, looking into it I found that the smoke is coming from 3 pin transistor labelled A008 on it, and on board it is U61, it is partially fried by now.
I have two spare motherboards but of different brands, a HP dv6000 and HP CQ61/G61 for parts, I was about to find and replace it but I stopped after noticing that the labelling for similar looking transistors on board is labelled Qxx instead of Uxx, and I cannot find any datasheet for A008 in order to find a part similar to this to replace.
Kindly let me know if any similar transistor can be used from the spare boards I have, if that is not possible then kindly link me datasheet for transistor A008 so that I can try finding myself. I was able to find datasheet for the motherboard which I attached but couldn't understand much.
Thanks in advance.
Thanks in advance.
