I am seeking some help from the experts here, please.
There is no 3.3V standby voltage and so the set appears dead.
I found the same model with the same symptoms on this forum under https://www.badcaps.net/forum/showthread.php?t=50363 .
budm tried to help but the tread ended quickly without any final conclusion.
Schematic of the power supply board (attached below) is from the above mentioned tread. It says there that it is for this specific model. However, the IC1 which drives the standby transformer TS2 is Viper12A on the schematic, while the IC1 on my board is FSQ510 (7 pins chip). Other components though seem to agree.
I did check CB4, DB7 and ZB6 as suggested by budm in that earlier tread, they all appear OK.
There are no signs of overheating, no swollen caps, and diodes in the area check fine.
Two resistors RB30 and RB31 on the supply line to the transformer TS2 are shorted with a fine piece of wire (looks like a modification on the board).
There is another tread, http://ww.badcaps.net/forum/showthre...t=18338&page=2, this one deals with FSQ510 in Philips TV with no standby. Also ended unresolved.
Here are my measurements (all plugs, except 240V mains, disconnected from the board):
On Main Filter Cap (C1, C2) 337V
On Filter Cap CB1 (for stand by supply) 337V
On IC1 (FSQ510)
pin 1 (GND)
pin2 (GND)
pin3 (Vfb) fluctuates between 2.5V and 3.04V
pin4 (Sync) nil
pin5 (Vcc) fluctuates between 7.55V and 7.69V
pin6 no pin there
pin7 (D) 336V
pin8 (Vstr) fluctuates between 297V and 304V
On Connector P2 no voltage on any of the 12 pins.
Discrepancy between the schematic showing IC1 as Viper12A and the board showing FSQ510 confuses me. Would they be compatible? Would this be a possible problem?
Not sure where to go next? Any help would be appreciated.
On IC1 (FSQ510)
pin 1 (GND)
pin2 (GND)
pin4 (Sync) nil
pin6 no pin there
pin7 (D) 336V
