This is a 30" LCD obtained through Craigslist. The previous owner indicated it worked well for some time, then started shutting off after several hours. Gradually the 'on time' decreased until it would no longer come on. With TV, remote, and users manual in hand I headed home with my treasure.
Setting it up and turning it on I noticed the backlights flashed very briefly - much less than half a second. Suspecting a shorted driver in the inverter, I pulled the back and started tracing. The connectors on the inverter were conveniently labeled, and a quick check showed the BL_ON signal went low briefly, then went back high. Conclusion: Not the inverter or the CCFLs.
Early the next morning I tried again. This time the backlights stayed on, I was able to bring up the menus, etc. As expected, it had static on the analog channels, and hooking the DB15 connector up to a computer I was able to get a good display. After about 15 minutes the display blanked again. I have been unable to revive it, other than the brief flash.
With power hooked up and the mechanical push-push switch on the side pushed in I get a red LED if the TV is turned off from the remote. Pushing the Power button on the remote causes the LED to turn orange for a few seconds, then green. About 5 seconds after going green the backlights flash. The LED will stay green as long as a video signal is fed to the TV. If the video signal is removed, the LED will go orange after about 1 minute.
I've pulled the power supply boards and all of the caps have an ESR below 0.1 ohm with the exception of two 10uF 450 volt caps on the standby power supply board. They read about 3 ohms. Even the main 820 uF 250 volt caps ESR is below .05. There were no obvious sign bad solder joints, and all power supply outputs seem to be normal. I'm not sure because this TV was designed to use two different LCD panels requiring different voltages and some of the boards are used for both LCD and plasma sets.
Abnormailties
The service manual indicates that by pressing 062596 Menu the set will enter Service Default Mode (SDM). At that point the front LED should start blinking any error codes. The LED flickers indicating it is receiving the key presses, but no error codes are flashed.
The service manual also indicates SDM can be started by shorting a pair of contacts on "the TV board", but doesn't give much help locating the contacts.
Any suggestions?
PlainBill
Abnormailties
Any suggestions?
PlainBill
