PCB layers
    PCB layers
    Is there any reliable way to determine the number of layers on a PCB??
    Thanks to all for being__WAR_KITTENS____!
    Re: PCB layers
    Not always, but some PCBs actually do have the layer numbers stamped on the board on each layer.
      Re: PCB layers
      Diamond saw and jewelers loupe is the most reliable way. As an alternative you can drill out a through hole via, something on the corner of the board that a mounting screw would go through, and then count the layers inside the hole.
