Dell P2411HB Buzzing noise at 80 percent or less brightness setting
Full brightness setting is quiet, but if you go down below 80% it will buzz real loud, it turns out to be a cracked Ferrite core of the LED switching power supply.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None
Re: Dell P2411HB Buzzing noise at 80 percent or less brightness setting
I used gel super glue to join the crack together, and then pot it with epoxy. It is still running on the bench.Never stop learning
