Compaq wassit?
    Re: Compaq wassit?
    I have a speaker connected
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
      Re: Compaq wassit?
      Pull mobo battery for a few minutes.
      Disconnect all drives [except as below] and see if you can get to a BIOS screen.
      Leave one known good hard drive connected to only the PSU [not ot mobo] as a dummy load for the PSU.
      Mann-Made Global Warming.
      - Dr Seuss
        Re: Compaq wassit?
        Right have tried that thank you and nothing. I am seeing quite a few GA boards with the spinning CPU fan syndrome
          Re: Compaq wassit?
          Do you see the yellow SMD switch labeled CMOS I reccomend unplugging the psu from the back power cord and removing the battery then holding the power butten on the case it will act like its going to boot but its unplugged caps are discharging. Once you have done that hold that clear CMOS button down for a few seconds without the CR2032 coin battery installed then release it reinstall the battery plug the PSU back in and see if your board will post properly with the CMOS cleared to factory default
