Hey Guys,
I want to replace the capacitors on this board. Most are swollen, some are leaking.
This computer came from my son-inlaw and it took me almost 2 hrs just to clean the dust out. After I disassembled it. I'm thinking this was a major contributor the the failing capacitors.
Listed below are the capacitors I need to replace. I have already replaced 6 capacitors with Rubicon 10mm x 20mm 2200uf 6.3v. (direct size replacements)
These are what I need and can anyone tell me what is the best brand to put in?
8mm x 16mm - 1000uf 10v (need 5)
8mm x 20mm - 1800uf 6.3v (need 5)
10mm x 20mm - 2200uf 6.3v (need 8 more)
Anyone have any suggestions as to maybe I should go with a higher voltage rating? What does the uf rating have to do with? Can I go higher or lower on this?
