Samsung Syncmaster 713N
    Re: Samsung Syncmaster 713N
    Originally posted by SmartVision View Post
    Ok thank you.
    Can you tell me what transistors are those , I need to buy them online.
    They are Rohm 2SC4672 with the Q gain option. They are available on eBay 5 pieces for $5 with free shipping, and they do ship to Croatia.
    PlainBill
      Ok thank you very much =)
        Hi there again , I'm back .
        I changed transistors that were shorted , lamps are working fine but I'm so unlucky becouse there is a new problem.
        Watch the video:
        http://www.youtube.com/watch?v=6vYMY...DMib69tj_ABJs=
          It looks like the ribbon to the T-con might not be fitted correctly or it might need a clean. Double check the connections.
          If that doesn't make a difference then I think we need to get you to do some more testing.
          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
          How to resize your pictures guide click HERE
          Retiredcaps Ideal post example click HERE
            Uhh , I dont really understand what is T-con ?
              There should be a cable that is attached to the main board ( signal board, logic board ) try taking it out and re attaching it again.
                I tried reattaching all cables but it didn't help.
                  We mean the end of the cable where it attaches to the screen panel.
                  Have you done that end or just the board end.
                    Ok I did that (see the picture to know if we meant the same).
                    But there is something weird , in my first video I posted , when I turned monitor on it went from white to blue and to black.
                    Now it went from white to blue then some weird lines blinked and then it went to black.There is some difference now and before but I dont know does it mean anything ? You can see the new video.
                    http://www.youtube.com/watch?v=QV8uv25dvAs
                      Not sure what the change on the video means .
                      No that is not the lvds cable it is the one that goes to the board attached to the panel/screen with lots of wires (Look mainly Blue& white?) in it. Checking for broken pins.
                      Something I dont think you have done since replacing the transistors is to test the output voltages from the power board (the socket with the black and red cable). These need checking with it all switched on and connected up.
                      Off topic:
                      I am visiting Dubrovnic next month how much is a can of beer./bottle of wine/ bottle of whisky in a supermarket.
                        Hehehe , you can get beer for 1-2 dollars , bottle of wine 4-5 dollars , whisky 10-20 dollars (dunno which one you want)... I'm sure that you will enjoy in Croatia Ask whatever you need
                        P.S. Does anyone know where is PlainBill
                          I measured output voltages:
                          1 - 0V
                          2 - 0V
                          3 - 12.98V
                          4 - 12.99V
                          5 - 12.99V
                          6 - 7.93V
                          7 - 7.93V
                          8 - 12.92V
                          9 - 10.94V
                          Is that fine ?
