HP M6 Blown transistor on LVDS circiut
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: HP M6 Blown transistor on LVDS circiut
    Lvds 3.3v power does not provide voltage to the inverter. It is the easiest way to see that you do not have any other problems.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Q29 broke into two pieces, I barely touch the thing.
      I removed Q28 dual FET in one piece. I bridged Q29 source to gate and tried it. It didn't work, but no smoke. I went back and took some readings, noticed pin 4 on lvds cable has continuity to the newly bridged Q29. I removed the bridge, and test further.
      Source on Q29 goes to pin 4 on lvds. Q29 drain goes to pin 4 Q28 (upper right pin) but also goes to pin 2/3 on LVDS. There's 100 Ohms between Q28 pin 4 to lvds pin 2/3 but 0 ohms to drain on Q29.
      if that makes any sense.
      Also, Q29 source still has 3.3v reading but gate has 2.7v reading, which wasn't there before.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Should I attempt to bridge source and drain on Q29?
        • atsio
          • Oct 2013
          • 819
          • Greece
          If you have voltage on gate of Q29 find a pnp fet and replace Q29. Also resolder Q28
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            Will any PNP fet work or does it need certain specs?
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              On the piece of the schematic I attached on my earlier post, it uses an AO3419.
              http://elcodis.com/parts/402616/AO3419.html#datasheet
              Find a similar (or the same) and replace it.
              • Duncanbest
                • Jul 2012
                • 81
                • Taiwan
                #27
                Q28
                Q29
                marking 01 STP7401
                https://cdn.badcaps-static.com/pdfs/...5446c39a04.pdf
                marking o1 Si2399DS
                http://www.vishay.com/mosfets/list/product-67343/
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  #28
                  IT'S ALIVE!!!!
                  reference: https://www.youtube.com/watch?v=1qNeGSJaQ9Q
                  I was able to find suitable replacements from digikey, replaced both Q28 and Q29.
                  It was a pain getting the sot-363 back on, and I wasn't expecting it to work on the first try or at all.
                  THANK YOU SO MUCH atsio and Duncanbest.
                  • mawa1105
                    la-c582p blown transistor
                    by mawa1105
                    I found a blown transistor (q24) in the picture. I replaced it, and it blew again 🤔
                    If I measure the Voltage while turned on without the transistor on the pads, it is 10V, 3.3V, 0V The resistance if turned on: High, High, 0.
                    Anny idea how I could proceed?
                    Regards
                    Mawa...
                    12-23-2023, 07:53 AM
                  • cmlewis89
                    LG 47LB5DF blown power supply board
                    by cmlewis89
                    Hi folks,
                    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                    09-03-2024, 07:50 PM
                  • NolesFan
                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                    by NolesFan
                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                    10-24-2024, 06:36 PM
                  • Kenny Low
                    AMD 6800XT Reference Model
                    by Kenny Low
                    Hi all, first of all, I am not able to find the schematics or boardview for this gpu model, so I am hoping someone here will point me in the right direction. I am a newbie.
                    This gpu fans all stopped working after doing fan replacement. Some components of on the pcb board blew up during the power up. The cause of this was realised shortly after that the 12v wire
                    was carelessly caught in a screw which in contact with the fan shroud. The fan shroud of this gpu is made from metal and hence shorted to ground.
                    Attached pic of the pcb with the burned component and pic...
                    09-23-2024, 09:19 AM
                  • harryw
                    Lite-On PA-6601-1 - seeking help to identify blown transistor Q307A
                    by harryw
                    trying to revive a dead power supply Lite-On 600W TESLAconverter PA-6601-1 manufactured in 2003 and originally used in a PowerMac G5.
                    Transistor Q307A underneath a heat shield was blown - it was labelled A2700 H403. How do I go about finding a replacement transistor?
                    Thanks & cheerio, Harry....
                    07-04-2020, 03:00 PM
