New Home 672 Sewing Machine Capacitor
  • Ghillie2012
    • Dec 2012
    I am new to the badcaps forum and was hoping for some advice, I stumbled by your site while trying to find information relating to repairing a blown capacitor in an old sewing machine that I inherited from my grandma.
    I found a thread a few years back that was very informative but was for a Brother sewing machine that was wired in a different way, I was hoping that someone may be able to help me identify a suitable replacement capacitor for my machine.
    The sewing machine is a New Home Model 672, manufactured some time pre 1990. The capacitor that is causing the issues is located in the foot pedal and through my current research I believe that it is an X capacitor used for smoothing, to reduce arcing in the speed control mechanism and noise from the motor.
    The sewing machine is wired like this:
    The capacitor has the following written on it:
    ERIE
    A4038H
    0.15uF
    600v D.C Wkg
    250v A.C Wkg
    Y SA
    The makers name isn't ERIE, that is the middle of the name, the rest of the letters have worn off. There was a little more written on the back but again it's all rubbed off. It made quite a bang when the ends blew off!
    Based on information I've gathered on this forum and on the web it looks to me like an X capacitor, I'm guessing that a Y type capacitor wouldn't be suitable as if it was to fail in this setup I wouldn't know. If an X capacitor in this setup fails it would blow the fuse in the plug and I'll know there is a problem.
    I have found the following capacitor on eBay that at first glance has similar voltages, the same capacitance, suppression application and is an X2 type. Would it be suitable as it's not a foil type design with exactly the same voltages?
    Feel free to tear my amateur attempts to identify everything apart and point out any errors I've made.
    I would be grateful for any assistance in locating a suitable replacement capacitor.
    As many people have mentioned both in the Brother sewing machine thread and on other sites I have removed the capacitor and the machine is now working again but I do not consider this a suitable solution as the capacitor has it's part to play in the life expectancy of the other components in the machine.
    Cheers, Nick
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: New Home 672 Sewing Machine Capacitor
    a .15@600v orange drop type will do fine.
    erie is a cap brand.
    your ebay cap should be fine too if its not a cheap counterfeit.
    • jamesbo
      • Aug 2011
      • 36
      Farnell UK also lists that same cap.
      • Ghillie2012
        • Dec 2012
        Awesome, thank you for your quick replies.
        I've ordered the capacitor from Farnell and saved myself a few pounds.
        Thanks everyone for your help.
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • CG2
          Janome DC3050 Sewing Machine Pedal Resistance
          by CG2
          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
          04-14-2023, 07:53 AM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • bohaboha
          Sewing machine Husqvarna 1610 electric contact
          by bohaboha
          can someone say how to put this plug together, there are two cords, one goes to the pedal and the other from wall plug to sewing machine. Don't know if the pedal should get its power from the motor, it's a bit confusing because the two cords coming from the motor are brown colored, don't know which is live or ground the blue and brown cord comes from the lamp. if anyone knows grateful...
          04-22-2023, 08:05 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
