Abit SE6 bad caps replace
  • Leo
    • Oct 2003
    I have an abit SE6 with bad caps.
    Because I can't find cap of the right value in Italy (1500uF
    6.3V), i'm thinking to replace them with 1200uF 6.3V or 10v (panasonic fc serie 105).
    I replace them calmy or there are problems ?
    Leonardo
    2
    Work great, as with 1500 uF
    0%
    2
    Smoke, smoke, fire....
    0%
    0
    It works but.... very unstable
    0%
    0
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    HMMM... Not too sure about that one... I'm sure the board will work after replacing the 1500uF caps with 1200uF caps, although stability would be one of my bigger concerns.
    I would try it though, that's not an enormous change, and more than likely it will be OK.
    If you need some 1500uF caps, go to www.digikey.com and order part number P10228-ND. Those are 1500uF 10v caps. They're 10mm diameter, and that company does ship internationally. They're a little pricey, and primarily sell in bulk, but you might give them a try.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Leo
      • Oct 2003
      Thanks for the advice but to buy from www.digikey.com is too expensive for me: 18 caps with tax and handle costs 23.10 $ + shipping (the less expensive ) 18/32$ + 20% vat of my country + +/-10% customs taxes = 72.73 $ (61.61 euro).
      I will try 1200uF caps and if the board will not work great, I'll throw it away.
      • stretch0069
        Screwed Up Super Moderator
        • Oct 2003
        • 2662
        • oooo ess aaaaaaaaa
        WHOA!!!!!
        I just sent a VP6 to Germany. It took 12 days and cost $22 to send. Then, if I understand him correctly, there was a ≈$10 fee to get it out of customs. I used US Postal Service.
        20 caps are ≈$20. Estimated shipping 4-10 day Air to Italy is ≈$15. So, as an estimate, it would be about $40 US. Someone here could order the caps and then readdress them to you. Only thing is, it would most likely take three weeks. Thats via US Postal Service.
        I might have the P10202-ND caps on hand. They are the 1500µf 6.3v caps.
        You could also see if TopCat has them on-hand and how much he could send them to you for.
        "Its all about the boom....."
        Guns kill people like spoons made Rosie O'Donnell fat.
        We now return you to your regularly scheduled drinking.
        "Fear accompanies the possibility of death.....calm shepherds its certainty"
        Originally posted by Topcat
        AWD is just training wheels for RWD.
          by momaka
          03-12-2025, 03:42 PM
        • ziplock
          Abit BE6-II motherboard
          by ziplock
          Greetings,
          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
          04-20-2025, 02:09 PM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • kupa97
          Help recapping DFI motherboard
          by kupa97
          I have a DFI LANParty UT nF4 Ultra-D with A TON of bad capacitors and I need help deciding which caps to replace them with, I've never done this before so I'll use this as a learning experience. I have included a color-coded photo of every single bulging capacitor on this motherboard. All bad caps are KZG, the KY and KMG caps seem to be in perfect condition at least visually. I've read about replacing these caps with polymer ones, but I'm not sure which ones to buy. Thanks.
          BLUE = 470uF 16v 8mm x 11.5mm
          GREEN = 1000uF 6.3v 8mm x 11.5mm
          PINK = 1500uF 16v 10mm x 19.5mm...
          11-23-2025, 11:36 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
