Samsung UE58TU7100K - powering cycling on and off
  • djmka
    • Aug 2021
    • 35
    • England
    I have a 58" Samsung that has an issue whereby it will not display a picture and cycles through its powering on process. The backlights come on for 1-2 seconds then go off. I removed the rear of the television and removed the grey flat cable going from the mainboard to the lefthand side COF (this is linked to the righthand side via a thin ribbon cable) and the backlights come on and stay on. No image is displayed (obviously). Sound can be heard through the speakers. I reconnected the flat cable and disconnected the righthand side COF and the tv behaved like it did when I disconnected the larger cable. This led me to believe there must be a fault on the right COF. Can anyone advise me what tests I can perform on the COF to determine exactly which component has failed.
    Thank you in advance.
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung UE58TU7100K - powering cycling on and off
    This already been discussed a lot, search for *UN58TU* in this forum.
      09-07-2024, 05:50 AM
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
