hi, i have a samsung 2220 syncmaster that just went black.. the blue power button flicks but no screen... i was wondering if it might be a capasitor? i don't know how to remove the back of the monitor.. it has 3 screws for the base stand... and 4 seems like holes in the back of the monitor.. any help would be much appreciated... thank's griff
samsung 2220wm syncmaster
Re: samsung 2220wm syncmaster
Originally posted by griff View Posti was wondering if it might be a capasitor? i don't know how to remove the back of the monitor.
http://www.youtube.com/watch?v=Ul5LhuCT1y8
You basically need to pry the thing apart.
After it is apart, post clear focused pictures after reading
https://www.badcaps.net/forum/showthread.php?t=1868--- begin sig file ---
--- end sig file ---
Originally posted by griff View Posti checked the capasitors and there were 2 bulged... i replaced them and now i see the screen is very dark.
Can you see the display if you shine a flashlight on it?
Or do you just see a black screen (no display image)?
When you power off, then power on, does the display work for 2 seconds and then go black?
Does the power LED stay green?
Also, it would help if you post clear focused pictures of all your boards (top down, front and back) after reading these instructions ...
Originally posted by seanc View PostCheck for fuses in the power supply which may have failed.
Some fuses are picofuses and can be spotted on boards with the identifier pf. For example, on the PCB it may say pf700.
A good fuse should read 0.3 ohms on your multimeter. Always measure fuses with power off and unplugged.--- begin sig file ---
thank's again for all your help..there was a problem with the ribbon...when i re-installed it the connection wasn't snug. once i snapped it in place it worked.. thank's for your help..it probably would cost me a lot of money with out your help..thank's again...Griff
Originally posted by griff View Postthank's again for all your help..there was a problem with the ribbon...when i re-installed it the connection wasn't snug. once i snapped it in place it worked.
I managed to break off one of those snaps by lifting them. It works, but I have to tape down that snap.--- begin sig file ---
