Samsung 19" power cycling
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi there!
    I have this Samsung UE19D4003Bw that suddenly started doing a power cycle at soon as it got AC in.
    I can see both the BL and the front led blinking fast
    I opened it and found nothing clearly broken or visibly burnt, no visible bad caps.
    I removed the PS to MAIN harness and nothing changed
    Also removed BL plug and front led still blinking (not a powerup process blinking but a fast blinking)
    I checked DC at the main capacitor and found a correct >300V voltge
    I went to the primary section in the main transformer and found no AC voltage on inputs, just "remains" 0-5v at times
    I can't spend much money in such a small / cheap TV set by just going ahead and changing the chopper IC (FSGM0765R), transistors, diodes and capacitors, so I would truly appreciate some comments from experience on what to test first
    PS model is BN44-0467A. Im attaching an schematic of one that's either the same or very very similar.
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: Samsung 19" power cycling
    Hi there!
    • edugimeno
      • May 2017
      • 581
      • Spain
      (Sorry for the duplicate post)
      Anyone? Thanks
        09-07-2024, 05:50 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • bcstedt
        Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
        by bcstedt
        Just starting to crack into this one and wanted to get the ball rolling.
        At power on (plug in), power light on, relays click, repeat (sometimes)
        After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
        Removed Y-Main for inspection and testing
        This pic from:
        PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
        12-15-2023, 10:30 AM
      • JSin21
        Compatibility of main boards between different variations of samsung MU6100
        by JSin21
        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
        I have Samsung Smart TV UA65MU6100WXXY version DA01
        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
        11-27-2023, 04:54 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
