Is this Samsung UN70NU6070FXZC 70 inch TV worth keeping?
  • Lupin3
    • Jan 2022
    • 29
    Have a UN70NU6070FXZC that I finally got working with the tape trick (youtube video) covering some of the LVDS cable connections. Picture was great for a few months then I went to turn it on one day and got no image. Background LEDs and sound work ok but I tried many combinations of the tape trick but couldn't produce an image this time. Could I have just been extending the death of the panel? From what I researched, is it the video driver that may be toast?
    Any input would be appreciated...
    • 12331
    • U.S.
    Re: Is this Samsung 70 inch worth keeping?
    see what kind of dispaly you get with one tcon ribbon at a time hooked up, always hook and unhook cables with tv unplugged.
      • 12331
      • U.S.
      your tcon might have went out, 2 months on the tape cut-off method seems very short.
        • 12331
        • U.S.
        see if you have 12 volts on each side of tcon fuse, neg. probe on chassis ground.
        • Lupin3
          • Jan 2022
          • 29
          Thanks for the suggestions...
          On this model, the T-Con board is part of the Main Board.
          I'm not sure what to measure on the main...
          • Lupin3
            • Jan 2022
            • 29
            Plus I tried to hook only one ribbon at a time and nothing...
              • 12331
              • U.S.
              if you have optical out port on mainboard is it lit red?
              • Lupin3
                • Jan 2022
                • 29
                What are the 2 outcomes of the optical out light if lit or not lit?
                  • 12331
                  • U.S.
                  ok, unhook lvds from mainboard to panel driver board. Test the little caps on the panel driver board, test for a short, diode mode, neg probe on ground, pos probe on each side of capacitor, doesn't matter which probe goes to ground in this case, one side should continuous beep or read close to 000, other side should not beep or have a reading something far from 000, if you find a short, it may be only one cap or it may be something else making it read short. Can also test for very low ohms in ohm mode, these tests done with tv UNPLUGGED from power.
                    • 12331
                    • U.S.
                    if steady light, the mainboard may be ok, if not lit mainboard probably has a problem, if not lit, maybe unhook cable from mainboard to panel driver board, see if it lights up. ALWAYS make connections with tv unplugged, to avoid any unwanted surges that can happen sometimes.
                    • Lupin3
                      • Jan 2022
                      • 29
                      Sounds good. I'll diagnose and report back another day (must get some zzz's for work).
                      Thanks "nomoresonys"
                      • Lupin3
                        • Jan 2022
                        • 29
                        Re: Is this Samsung UN70NU6070FXZC 70 inch TV worth keeping?
                        Optical Lite works on Main Board.
                        I hope I am testing correctly (see attached pic)...I tested the caps and most read properly as you said but 3 or 4 caps I cannot get them to beep or measure. Is it possible to block these caps out with tape on the LVDS lines? I know the video driver board is one unit with the panel and I'm far from being a pro about replacing caps...
                          • 12331
                          • U.S.
                          I thought you said you already tried it in the first post but it didn't work again.
                          • Lupin3
                            • Jan 2022
                            • 29
                            Yes it did work with the tape the first time. This time I can't restore the image after positioning the tape in endless ways...perhaps more caps blown?
                            I'm a newbie at attempting to fix this and trying to justify a big spend on this tv with the warranty now expired.
                              • 12331
                              • U.S.
                              those caps are very inexpensive, you can also probably find them in an old laptop or such, just need to make sure they are labeled with a C for cap and not L for inductor, they can look similar but are not the same.
                                • 12331
                                • U.S.
                                probably need to verify a short first tho, maybe you know someone who can do some soldering or can work with these types or maybe practice on a scrap board.
                                  • 12331
                                  • U.S.
                                  It isn't particularly hard but it can take some patients and a little practice, dealing with small parts.
                                  • Lupin3
                                    • Jan 2022
                                    • 29
                                    Yes - patience I got but I drink too much coffee to work on replacing the caps because of the small parts involved you really need steady hands.
                                    I checked the other side of the driver board and found a few caps not beeping too... should all caps be showing something when tv is unplugged?
                                    Can I definitely rule out a Main Board issue? Was hoping to buy a replacement but if this is not the problem then I guess will sell it for parts on ebay...
                                    Thanks for all your help by the way
                                    • Lupin3
                                      • Jan 2022
                                      • 29
                                      I've checked (continuity) more caps on the integrated Main/T-Con Board and found some not reading either...I'm testing with the power unplugged.
                                      If anyone could help me in deciding if there's a chance that the Main Board is not functioning correctly and keeps the led driver/image from showing?
                                      I know there's are a lot of factors at play here but to narrow down to only one problem item (if that's even possible) would help me decide if to order an expensive Main Board or call it quits b/c of the video driver/panel.
                                      • Lupin3
                                        • Jan 2022
                                        • 29
                                        Ok, after more tedious trial and errors with the tape trick, I managed to have an image once again!
                                        I even managed to eliminate any horizontal lines by moving the tape to different pins.
                                        The only thing I can't get rid of is that across the 1/4 to 1/3 top of the screen is a brighter bar noticeable from all the lower part of the entire screen. Can't watch without noticing it!
                                        I'm stuck...
                                        Any suggestions?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
