Hisense Roku Tv 55R6E3 steady red led help.
  • ivtec
    • Dec 2008
    • 1967
    Hi folks i need your help ,have here a tv that i found on the curb and i'd like to repair it if it doesn't cost me much since i don't have no 4 k tv,
    Are these Voltages going to the main board Ok?
    Unplugged from main board
    0.00v
    0.00
    20.20
    20.20
    0.00
    0.00
    9.20
    9.20
    Plugged to main board
    0.00v
    0.00
    20.20
    20.20
    0.00
    2.93
    12
    12
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hisense Roku Tv 55R6E3 steady red led help.
    Would be nice if you identified them.
    • ivtec
      • Dec 2008
      • 1967
      0.00v
      0.00
      20.20
      20.20
      0.00
      0.00
      9.20
      9.20
      0.00v
      0.00
      20.20
      20.20
      0.00
      2.93
      12
      12
      • diif
        • Feb 2014
        • 6978
        • England
        Write them next to the voltages.
        • Diah
          • Feb 2013
          • 6374
          if you mean this V messurments you took as you wrote.. then yours Power Boards are fine.
          0.00v
          0.00
          20.20 AMP (sound 20V)
          20.20
          0.00
          2.93 STB
          12 12V
          12
          next you need to read the V on the BL Socket direct on the RED and WHITE cable and capture the V at start up if its go hoch.
          • ivtec
            • Dec 2008
            • 1967
            Thanks Diah ,i did measure Black probe to chassis GR - Red Positive to white wire i get 225v DC either plugged or unplugged. thanks
              • 12196
              • U.S.
              you only have one other connector, it's right there says xp702 beside it, check voltage at start up see what it does, how high it goes and what it settles at.
              • ivtec
                • Dec 2008
                • 1967
                Thanks mate; the tv when i plug in power plug it get a steady standby red led ,when i press power on tv it blinks 1 time and goes steady red. I probably suspect led lights ,they are prone to fail frequently on these cheap modules.
                  • 12196
                  • U.S.
                  could be, that test there in post #5, can help, probably set meter to 200 if meter is not auto-ranging or you get OL.
                  • ivtec
                    • Dec 2008
                    • 1967
                    My DD meter is fluke 78 auto range.
                    • Diah
                      • Feb 2013
                      • 6374
                      take the screen apart.
                      • ivtec
                        • Dec 2008
                        • 1967
                        Thanks mate ;but it's too much hassle,too big and leds are too expensive ,not worth it, i have also a 50''ONN 4k Roku tv on my bench open up and i need the leds but i don't want to spend money , also i thought i could find the fault at component level, i don't real need 4 k for now and i have about 10 1080p tvs that i was lucky to repair at component level, i appreciate your trying, thanks.
                          • 12196
                          • U.S.
                          well we can try to determine what's wrong maybe, what does the tv do or not do exactly?
                          • Diah
                            • Feb 2013
                            • 6374
                            still you have screen 55 size to use
                            wish some one explain what did this words " fluke" mean... it got at my poor English mind the meaning of not stable when even google 404 stopped to understand it LOL.... so i wrote
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              Fluke in this case mean a manufacturer of a meter,
                              https://www.fluke.com/
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                I have a Hisense Roku TV and it normally has a constant red light when off then when I press the on button of the remote it blinks once an waits about a second and blinks again and then the picture comes on. This happens only when the TV has been off for a while. If the TV was just been powered off the red light does not blink at all it just turns on. Thought this information might help. I would think the blinking of the red light one time means it made it through a certain part of the power up sequence. Wonder if it would be worth trying to flash the bios if that is possible?
                                • ivtec
                                  • Dec 2008
                                  • 1967
                                  Hi mate; when i mentioned my DM Fluke 78 it was to respond to Mr nomoresonys; that mentioned ,quoted; could be, that test there in post #5, can help, probably set meter to 200 if meter is not auto-ranging or you get OL.
                                  https://www.testequity.com/product/1...caApP8EALw_wcB
                                  • ivtec
                                    • Dec 2008
                                    • 1967
                                    Thanks Kenny. Since you mention all that about your Roku tv .Today i went down to seller where i have the Tv. connected tv to power outlet i notice that it's not a steady red led, as soon i plug in the power plug it goes red and then gives 1 blink every about 15 seconds or so.I never prayed attention to that detail since i'm getting older and my eyes are not what what they use to be .i have a tight place to work on my tvs ,my son moved in after a failed marriage and occupied my work place where i use to work on my tvs, with furniture and all his stuff, so i have no room ,light or space to test my tvs properly that i love to work on.
                                    I can try to flash the Bios on this tv ,can you share detailed info on how to do it. Thanks i appreciate your input.
                                    By the way does a Roku device remote control, i have 3 , works with these Roku tvs ?
                                      • 12196
                                      • U.S.
                                      lol, he was responding to Diah, I guess Fluke isn't as popular over seas.
                                      • ivtec
                                        • Dec 2008
                                        • 1967
                                        I understand mate.I bought 1 for me and another for my son that is a mechanic many years ago ,best money spend . These Fukes 87 are outstanding.
                                        • DoubleBogey817
                                          HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                          by DoubleBogey817
                                          HISENSE 65H6510G (13 AUGUST 2020)
                                          When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                          02-16-2024, 10:58 PM
                                          Huawei MateBook 14 2020 Netbook 14 Specification for Upgrade or Repair
                                          This specification for the Huawei MateBook 14 2020 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 2020 boardview and 14 2020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei...
                                          09-06-2024, 10:20 PM
                                          Huawei MateBook 14 2020 Notebook 14 Specification for Upgrade or Repair
                                          This specification for the Huawei MateBook 14 2020 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 2020 boardview and 14 2020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei...
                                          09-06-2024, 09:10 PM
                                          Huawei MateBook 14 2020 Notebook Specification for Upgrade or Repair
                                          09-06-2024, 08:40 PM
