Originally posted by ggil44
View Post
UN70NU6900FXZA power cycle, no picture - workaround found
Hello nomoresonys, Thank you for responding to my post. I do have the same model and I did try changing R13246 with values up to 100K ohm (please see my post #17 dated Nov 20 on this thread). I even tried masking the area of pin Possible prob on a Gigabyte board on the L ribbon cable without any luck. I am of the persuasion that the fault for my TV lies in the Right side buffer boards rather than the left side as experienced by itelite. The only way I can get a partially working TV is by masking the R ribbon cable, not the Left ribbon cable. Regards,
Hello again, I did some more testing with masking off pins and was able to identify the boot loop pin on the right ribbon cable. It turns out that pin 23 is the problem and when taped over, the TV turns on normally. It does however have a degraded picture that looks like burn in. With more testing I discovered that I could uncover all other pins except 19 or 20. With 23 still covered, if I cover 19 I will get very little color fade but I get fine lines and the appearance of burn in on the right side of the tv. If I cover 20 the color fades somewhat but not as much as when I covered all 13 - 24 pins and I don't get the "burn in" appearance. I decided to go with covering Pins 23 and 20 and live with the color fade. I wish I could find a trouble component like itelite but at this time, I feel this is better than nothing.
