ViewSonic N3760w LCD with bad caps
  • madman604
    • May 2013
    Re: ViewSonic N3760w LCD with bad caps
    well i got the caps from Digikey and replaced the suspect, but not obviously faulty caps.
    The TV got really weird. at first it seemed to be fine. then started turning on and off rapidly after a few seconds.
    turned it off and unpluged the tv. later it stayed on for 2 hrs and i turned it off and went to bed.
    next day it would randomly turn on then off again.
    any more ideas?
    • cosmicdust
      • Jul 2013
      I have a Viewsonic N3752 that about 8 months ago failed to produce a picture. There is no picture, a.k.a. “blank screen” no matter the input selected. There is, however, sound. The unit otherwise functions as far as I know. After some research, I concluded that the power supply (FSP271-5F01) may need repair, so I ended up ordering 15 capacitors (a "kit" was available for just this PSU, from many sources). I first replaced the three that were obviously “swollen” or bulging at the end (the sign of being blown), but there was no change. So I proceeded to replace the rest. However, now when the unit is powered on, there is a brief pause, then a click, and the screen flickers (did not do this before the "repair", simply sat blankly). I am not certain that it "clicked" like that when it was fully functional, but I think that it did. Additionally, there were two of the capacitors that I removed at the same time, a 220u25V and a 220u35V (from locations CS33 and CS6), that I did not mark when I removed, so it took quite a bit of research to figure out which one went in which location, but I am reasonably certain they are in the correct spots (CS33=35V; CS6=25V).
      Any thoughts, before doublecheck and resolder every wire I soldered…or I plunk down for a replacement power supply?
      Thanks in advance...
      • henpitts
        • Jul 2016
        I know this is an old thread but thanx for the info. I recently put a Viewsonic back into service and the wait time to hold the power button eventually went from 20 seconds up to about 3 minutes. Caps are swollen so I will order replacement caps.
        • madman604
          • May 2013
          Ive since dumped the tv. Wasnt worth the effort anymore.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
