Samsung QE55Q700T
  • Fridaycider
    • Feb 2022
    • 16
    • United Kingdom
    Samsung QE55Q700T
    Can anyone identify these diodes on the buffer board and tell me where I can get replacements , also has anyone got a service manual for this tv as can't find one anywhere.
    What sequence on the remote works for the service menu ?
    The tv reboots when been switched on for a while and want to check these diodes out as they seem to be a problem as I've read up on here .
    Tried 4xpsu,t-con,led and mainboards and seems to stop happening when I disconnect any ribbon cable from t-con to buffer boards.
    Display has no lines or defects from what I can see .
    Any advice is much appreciated.
    Thanks in advance the knowledge on here is a great help and learned soo much already.
    • 21145
    Re: Samsung QE55Q700T
    Is that an 8 or a B
    • Fridaycider
      • Feb 2022
      • 16
      • United Kingdom
      Looks like a B
      • R_J
        • 9555
        It should be DT1042-04SO-7
        • lotas
          • Jan 2016
          • 4649
          • Russia
          Dt1042-04so
          • Fridaycider
            • Feb 2022
            • 16
            • United Kingdom
            Thank you
            • Fridaycider
              • Feb 2022
              • 16
              • United Kingdom
              Wow , really hard to find any in the u.k.?
              • Fridaycider
                • Feb 2022
                • 16
                • United Kingdom
                D1213A-04SO-7 rs components say this is the alternative as DT1042-04SO-7 is discontinued?
                • Fridaycider
                  • Feb 2022
                  • 16
                  • United Kingdom
                  https://uk.rs-online.com/web/p/tvs-diodes/8270437
                  • Fridaycider
                    • Feb 2022
                    • 16
                    • United Kingdom
                    Originally posted by Fridaycider
                    Can this be used ?
                    • R_J
                      • 9555
                      Yes the D1213A-04SO should be fine to use.
                      • Fridaycider
                        • Feb 2022
                        • 16
                        • United Kingdom
                        Thanks for the help but not sure if needed now . Did the tape method and narrowed it down to the right hand connector and at the moment very slight temporary line in screen so need to look a bit further into it .
                        • Fridaycider
                          • Feb 2022
                          • 16
                          • United Kingdom
                          Be good if can get schematics. Also does anyone know the remote sequence to get to the service menu please ?
                          • lotas
                            • Jan 2016
                            • 4649
                            • Russia
                            Method 1 call the service menu
                            Put the TV into standby mode, turn off the TV with the remote control, then press the buttons on the remote control in sequence: “Info, Menu, Mute, Power”, then the TV will turn on and display the service menu.
                            Method 2 enter the service menu
                            Turn off the power. On the remote, press Mute and then 1, 8, 2 and Power
                            Method 3 enter the service menu
                            When the TV is in standby mode, press DISPLAY, P.STD, MUTE, POWER on the remote control.
                            Method 4 enter the service menu
                            When the TV is in standby mode, press SLEEP, P.STD, MUTE, POWER in sequence on the remote control.
                            Method 5 to enter the service menu
                            When the TV is in standby mode, press DISPLAY, MENU, MUTE, POWER on the remote control.
                            Method 6 to enter the service menu
                            On the remote, press Mute, then press 1, 1, 9 in sequence.
                            • Fridaycider
                              • Feb 2022
                              • 16
                              • United Kingdom
                              Thank you .
                              • lotas
                                • Jan 2016
                                • 4649
                                • Russia
                                Warning: the service menu must be handled with care. Incorrect operation may result in the inability to turn on the TV. By entering the service menu, you take full responsibility for the further performance of the TV at your own risk.
                                • Fridaycider
                                  • Feb 2022
                                  • 16
                                  • United Kingdom
                                  Need to try a factory reset but someone has set a code and don't know it
                                  • lotas
                                    • Jan 2016
                                    • 4649
                                    • Russia
                                    The reset can be done in the service menu "Factory Reset".
                                    More or less like this : https://www.youtube.com/watch?v=oN9AS2NvIbE
                                    • Fridaycider
                                      • Feb 2022
                                      • 16
                                      • United Kingdom
                                      Has anyone any information on removing the backlight panel on this model as the display is part of the frame and either the panel needs to be removed from frame or the backlight panel unclips from the rear leaving the panel on the frame . Not sure how to go about it ?
                                      • Fridaycider
                                        • Feb 2022
                                        • 16
                                        • United Kingdom
                                        I've unplugged the upper backlights and it's stopped rebooting on another set
                                        . The backlights are all working but can one be shorting causing this
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
