LG 70UH6350 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 624
    Got this tv and tracked down the problem to the mainboard. Tv standby light shows the tv turns On but no picture or backlights. Tested backlights with backlight tester and all is working well. Also I put in another mainboard to verify and backlights turn on fine.
    Anyways I cannot find another mainboard for this TV. So I'm trying to fix the board. Any suggestions on where to start?
    Could it be the eeprom possibly?
    I don't work on many lg TVs and usually when I do it's the backlights.
    Thanks I'm advance
    Pics attached with heat sink and with it removed.
  • Diah
    • Feb 2013
    • 6374
    Re: LG 70UH6350 Mainboard issue
    yours ways to take the point the MB working regard front indicatores or BL are absoult wrong.. sorry
    with original MB did you have the optical audio port lit on RED ??
    • Storyteller12
      • Jun 2020
      • 624
      Hi Diah, No optical audio did not show red
      • Diah
        • Feb 2013
        • 6374
        so it didn't turn on at all.. do you have after turn on 12V and 24V on the MB socket which it come from PCB?
        • Storyteller12
          • Jun 2020
          • 624
          Yes the red optical did not turn on at all. All voltages match what’s on the legend. Except all 24v measure 26v. But that should not matter as the 2nd main board I used to test with worked fine.
          • Diah
            • Feb 2013
            • 6374
            we are talking on original MB. not the test one.. 24 rail go to 26 mean you have at audio section issue or one of HDMI USB issue
            • Storyteller12
              • Jun 2020
              • 624
              I understand we are talking original board. The 26v is the same when mainboard disconnected from power supply. So would that rule out the audio or usb and hdmi?
              • Diah
                • Feb 2013
                • 6374
                no but this not normal what you are measuring. 2 v more on 24 rail will toast much parts on the section's i mentioned as 12 rail due to panel vcc
                • Diah
                  • Feb 2013
                  • 6374
                  can we see the power boards and the print label charts of its dc supply
                  • Storyteller12
                    • Jun 2020
                    • 624
                    All 12v on the legend measure 12v and so does the tcon when I checked that. It’s just the 24v that measure 26v. Not sure though cause everything is normal with 2nd mainboard.
                    So assuming it’s the mainboard anything specifically I can check?
                    • Diah
                      • Feb 2013
                      • 6374
                      MAn... you tested main boards with fault on PCB was there 24V are 26V. ( its short time to toast ) the original one which suffer from the PCB toasted already.. need first to bring this 24V rail to normal then working on the Original MB.
                      • Storyteller12
                        • Jun 2020
                        • 624
                        I’ll double check tomorrow about the 26v when disconnected from power supply. Maybe I’m wrong and that’s why the 2nd board worked fine.
                        That’s for the help. I’ll report back tomorrow after I confirm
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Did you get your 12v to panel?
                          Things you need on most mainboards. 5v, 3.3v, 1.8v, 1.2v, clock pulse
                          • Storyteller12
                            • Jun 2020
                            • 624
                            I got 12v on the tcon. Not sure about the panel as I have not hooked it up.
                            Every lg tv I’ve had needed the backlights replaced so I just assumed and removed panel.
                            To my surprise all leds tested good. So I have been troubleshooting with the panel removed for the time being.
                            Will update later on the 26v after I get to the office and test
                            • Storyteller12
                              • Jun 2020
                              • 624
                              Update. I made a mistake There is no power on the 24v pins with mainboard disconnected.
                              • Diah
                                • Feb 2013
                                • 6374
                                do you mean you run the PCB standalone with jumpers as mainboards disconnected from PCB so no 24V.. !!!
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  I did some testing on the main board and found a lot of shorted caps. I've marked them and uploaded a phot of it. Also I found an 8 pin ic I cannot find a data sheet for that is shorted to ground on 5 of the 8 pins.
                                  It's ic101 and labeled with marking 4G25 60473
                                  I'm thinking that may be the problem but not sure.
                                  Any further help is appreciated
                                  • nomoresonys
                                    • 12192
                                    • U.S.
                                    There wouldn't be would there, without the mainboard telling the powerboard to turn on?
                                    • nomoresonys
                                      • 12192
                                      • U.S.
                                      If you still have both mainboards, you can compare the readings to each other.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        So what voltages have you found?
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • alltvrepairs
                                          Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                                          by alltvrepairs
                                          I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                                          This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                                          Any help appreciated!...
                                          03-14-2024, 03:39 AM
                                        • dbuergi
                                          PS5 Dualsense controller stick drift a mainboard issue?
                                          by dbuergi
                                          I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
                                          I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
                                          05-02-2025, 05:00 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                          by ugamazing
                                          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                          12-17-2024, 07:05 PM
