LG 42PC3 buffer output doesn't follow YSUS
  • legg
    • Apr 2018
    • 25
    • canada
    LG42PC3D -UD originally with green lamp but no display or audio.
    Owner says was working, then went 'pop'.
    All 5V caps bulging. replaced.
    All PSU output voltages within spec but -Vy is low on YSUS.
    One of three parallel fets between SUS_OUT and SUS_DN is zenering,
    eventually shorts DG. Replaced all 3 - -Vy now OK.
    Y scan buffer test point does not follow YSUS output below -50V
    Note: This unit seems to expect YSUS output to park at -Vy in between
    drive signal pattern periods. A replacement drive signal board confirms this.
    This shows up in a training manual for early 60PC1D, as being normal. Later
    models will park at 0V . . .
    Also, YSUS waveforms sometimes show a double setup ramp before the
    single setdown ramp at pattern termination. This is only shown in training
    manuals for dual-scan types. It might be because I'm not supplying a white-
    screen input signal (no input source is present).
    A second buffer board produced first screen illumination, for a short period,
    before R15 popped, leaving only a top horizontal band illuminated (greenish
    random). R14 is 47R 2W smd - looks to be in an RCD snubber network
    configuration. Replacing the C and popped R allowed the same behavior to
    be repeated, with popped R15 again.
    I replaced the 74AC540S supplying signals to the buffer board and a second
    replacement buffer board gave full screen illumination without anything
    popping - but only running it long enough to get waveforms and images.
    There is a random greenish pattern, with a redish-yellow vertical band shifting
    randomly back and forth across the screen.
    The only similar random illumination images I've seen in plasma screen
    diagnostic literature refer generally to either loose connectors or corrupted
    memory.
    Reprogramming seems unlikely for this model - distributed for 6 months only,
    in 2006, even though it was subject to an industry-wide bug fault requiring
    widespread reprogramming, at that time. You'd expect programming tools to
    still be floating around somewhere.
    This unit was a revision within a revision - no PFC in power supply as with 42PC1x.
    Its YSUS board had 74AC540S and 74AC541D (different body sizes) on
    the same board
    Anyone with ideas what's next?
    Y buffer test point still does not follow YSUS output lower than -50V
    RL
    Last edited by legg; 11-18-2021, 12:02 PM. Reason: added typical wfm from training
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    by sam_sam_sam
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
