Samsung ue49mu6120
    Re: Samsung ue49mu6120
    Originally posted by lotas View Post
    Try
    nothing makes the same defect
      Try this one too.
        Try this one too.
        with this you don't see the SMART TV logo, but it still makes the same defect
          Then it turns out that the problem is in eMMC (it does not boot further).
            sorry i have seen reply late, the fault is in the panel for me, the same old fault, something shorted maybe in gate drivers, maybe in the panel small boards.. check if you have channels audio by putting in antenna cable and search for a good channel.. ** better to open own thread because of different model / symptom by the original thread!!! **
              I don't think it's the panel because in addition to not hearing the audio, it stays blocked and won't even let me turn it off from the remote control
                post the main board bn41 code
                it is not correct that one tv that pulses the status led is a tv with good standby software, sometimes not, already proven, so ask lotas or someone else for the correct spi file, then if it doesn't work try another file.
                  I make a video and see if I can upload it to show you the precise defect
                    if you have no video then you can simply explain the blinking sequence, no need of video clip (?)
                      the LED does not flash, i plug it in and the TV starts by itself showing the SMART TV logo for about 2 seconds and then disappears, only the backlight stays on. If I then try to turn it off from the remote control or from the button it doesn't turn off
                        Well, another option, try this dump
                          Sorry, maybe i have confused the post from someone else, with this type of defect the main software could be the culprit, don't waste time flashing the spi..
                            Yes, I already wrote that the problem is most likely in eMMC.
                              and the emmc I can not flash it? i have a tl866
                                no, you need at least a T48
                                  Samsung UE49MU6445UXXC
                                        Samsung ue40mu6400uxzt
                                        buonasera ..anche io ho lo stesso problema della 25w40 corrotta .....potete aiutarmi in qualche modo.....difetto riscontrato led standby spento staccando connettore collegamento main board solo retro illuminazione. Provato un dump trovato in rete , e' tornato standby ma non si accende .....vi ringrazio in anticipo .... allego dump originale 25q40
                                        MAINBOARD : BN94-12398F
                                        CODE: BN41-02568B
                                        MODEL: BN41-02568
                                        PANNELLO : BN95-03473A CY-KK040HGNV2H
                                        PANEL REV.00 BN96-39904B REV.01 BN39821C
                                        BN64-03429A
                                          Re: Samsung ue40mu6400uxzt
                                          CODE: BN41-02568B
                                          MODEL: BN41-02568
                                          BN64-03429A
                                          Try.
