Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
  • StromarMiki
    • Oct 2021
    • 25
    • Slovenija
    Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help.
  • StromarMiki
    • Oct 2021
    • 25
    • Slovenija
    Re: Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color proble
    how can i change t con panel 65 "to 55"
    Does anyone know?
    • lotas
      • Jan 2016
      • 4745
      • Russia
      All t-con settings and matrix type are in spi flash IC501 W25Q80V.
      • StromarMiki
        • Oct 2021
        • 25
        • Slovenija
        Super now work fine. Thank you.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Great results. Do you have any pictures of both boards? I want to take a look at them please.
          • StromarMiki
            • Oct 2021
            • 25
            • Slovenija
            SAMSUNG MAIN BOARD BN41-02662A,the board are identical to each other. The only difference is in the model and the screen.
            Difference sticker on the board.
            • StromarMiki
              • Oct 2021
              • 25
              • Slovenija
              For Samsung LED TV UE55NU7023 i need parts.
              - wall mounting screw holder 4 pcs
              - stand legs L and R
              Where can I get parts for this model. Or only no. parts.
                09-07-2024, 05:50 AM
              • Nairolf
                Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                by Nairolf
                I have a Samsung DM32D display.
                When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                Here’s what I have tried so far:
                1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                From these tests, I suspect the problem might be on the mainboard. Could anyone...
                08-24-2025, 03:47 AM
              • bohaboha
                ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                by bohaboha
                Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                04-19-2025, 01:47 PM
                09-06-2024, 11:40 PM
