LG 43UK6470PLC - no image
  • pi3141592
    • Apr 2020
    • 8
    Hi All,
    I have a 43UK6470PLC that was showing no picture at all.
    I got a replacement Mainboard + T-Con (combined unit) – part number EAX67872805 - as it was cheap and was hoping for a quick win. Unfortunately, no luck with that.
    So, looks like an LCD issue. If I:
    • remove the Left had side LCD driver cable – No Picture
    • remove the Right had side LCD driver cable – No Picture
    • tape over Pins 3-12 Left hand side LCD driver cable – Picture with some blank lines and flickering on the left-hand side.
    I'm trying to figure out exactly what pin I need to isolate but having difficultly as I think it could be more than one pin on both sides.
    Anyone have a schematic or know the pinouts for the LCD on EAX67872805? Or any other tips to help isolate what one it is?
    Many Thanks. Jas
  • pi3141592
    • Apr 2020
    • 8
    Re: LG 43UK6470PLC - no image
    Just an update.
    Got it working by covering pin 1-6 with scotch tape.
    Looks like this TV used the same mainboard and similar issue.
    https://www.badcaps.net/forum/showthread.php?t=82783
    Hope this helps someone.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Odd that one side did not come back when removing cable.
      • alfatv
        • Sep 2020
        • 353
        It's true with these series.
        The only noticeable difference between sides is that power supply shuts down when bad side is connected.
        • GodGecko
          • May 2022
          • Croatia
          i have the same exact issue on the same model.
          by covering pins 3 and 12 the TV works but with some flickering one the upper left corner
          • nomoresonys
            • 12330
            • U.S.
            same tv, maybe try blocking same pins as pi3141592 did in post #2, might not work but worth a shot.
            • note_fritz
              • Apr 2013
              • Portugal
              Hi All,
              Can someone please upload the bios fie for this TV / MAIN BOARD ?
              LG 43UK6300PLB MAIN EAX67872805(1.1) DUMP BIN BIOS EEPROM 32KB
              I have a TV here from a client thar has all voltages and the Pilot red light but cant turn on neather with the remote control.
              Thank you
              • lotas
                • Jan 2016
                • 4859
                • Russia
                Originally posted by note_fritz
                Hi All,
                Thank you
                LG 43UK6740PLA EAX67872805(1.1)
                • note_fritz
                  note_fritz commented
                  Editing a comment
                  Hi Lotas.
                  Thank you very much
              • Rozp
                70LE660U dark cloud or black screen with sound.
                by Rozp
                Hello Everyone,
                This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                08-29-2023, 05:25 PM
              • NSkyLab
                Sony XBR-65X900F black and white image on one side (fading saturation)
                by NSkyLab
                I though I've seen all possible kinds of failures but this one is new...
                Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                10-05-2025, 07:37 PM
              • MoreMagnets
                Sony KD49X8000H - Sound, backlight, no picture
                by MoreMagnets
                Hello all!
                This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                10-23-2022, 09:31 PM
              • ashyt16
                Toshiba TV bad panel half screen dark - pull tabs or not?
                by ashyt16
                Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
                The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
                Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
                I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
                10-26-2020, 05:47 AM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
